59 f250 wheel size
Hello forum, I'm looking at a 59 f-250 with 15" 5lug wheels, is this a true 250? Also, Where would the vin tag be on this truck? Thank you for your time gayle.sutton@am.jll.com or post here would be great
It could be a true F250 with F100 axles, or a true F100 with an F250 cab or just F250 emblems or most likely F250 fenders. Either way, it has been altered. Not sure if that qualifies you as a darksider or not.....At least it's a true fridge. Any pics?
An F-250 would have 8-lug wheels from the factory.Post up the v.i.n. .It is on the inside of the dispatch, or glove-box door.
The owner, or a previous one,may have installed the body onto a different frame.The vin is also stamped somewhere on the frame.I can't say where. |
Originally Posted by ibuzzard
(Post 11621851)
[quote=GB SISSON;11621847] Not sure if that qualifies you as a darksider or not.....quote]
No, it does not make you a Darksider! There has not been any intentional swapping out of FoMoCo parts for brand X! :D What you have there is real Ford with parts from two different weight classes! |
Whewww...close one.
Hey at least mine is all from the same (one ton) weight class. HaHa....Well maybe not the corvair throw out bearing. What's the gvw on one of them?;) ;)As for this F250 with the 15" wheels, we still want a serial number and a photo or two. What is the bed? Flareside, styleside, flatbed, long bed or short bed?
Thank ya'll for the info. The truck looks solid, with the normal f-100 stuff underneath. Cab is really solid, but I haven't looked at the mounts yet, has a sweet all vinyl black seat, body is a flare, with wooden bed rotting under a steel plate top (brilliant), looks like holly green under all black/bondo top color. I did see some highland blue on the door hinges, now im confused, but the paint tag'll tell me all soon. The guy runs a wrecker, has it in his yard for 1500, beside a 70 for 2500. I'm gonna lay 700 on the hood and go from there, just wanted to run it by ya'll first.
