9" rearend part# - Help to Decipher, Please
Hi Fellas,
I hope someone here has an early Ford Parts book that could decipher these early ('57-'60?) 9" Ford rearend part numbers: The carrier casting: WAB 4025A The differential castings: WAC-4205A, WAC 4206A Pinion Support Flange Stampings: WAA 11 4668B Stamped on the ring gear: WAA-4210-A OR24 916 Shift No.2 FoMoCo USA I was surprised to be able to make out on the tag: 3.70 The things I'd like to determine are: A) What model car/truck this center section likely came out of; B) What size side bearings it would have (3.063 or 2.89) C) Is the differential is a limited slip or open D) If the differential would accept 28 spline axles or ??? Thanks in advance of any & all assistance, Guys! :-X22 BarnieTrk :-drink |
