Can't change clock
When I hit the clock button to change the time on my 2011 F150 the numbers disapear instead of flashing to set the time. Anyone have this problem or any ideas?
Your owners manual says to press and hold the button until the display flashes.
Then use the seek buttons to change the digit. If you have the navigation system there are different instruction in the manual supplement. Owners Manual online at: https://www.fleet.ford.com/maintenan...ls/default.asp |
When the numbers disapear use the station number buttons to put in time
That is too funny! I found the F150 clock is the easiest to set out of any Ford I have ever owned. Push clock button and enter numbers!
Clock
Originally Posted by 11racered
(Post 11572090)
Originally Posted by tuckr2
(Post 11573690)
Just make sure you put it in park before trying to revise the time. I tried while driving. Didn't work until I put the truck in park.
I changed mine while driving as well. Not fast though, yeah, still probably the wrong thing to do ....
Originally Posted by loydmeeks
(Post 11572557)
When I first set the clock it was the easiest clock I had ever set but for some reason it didn't work as the manual said this last time. The numbers did not flash when I held the clock button, they disapeared and you couldn't use the station up/down buttons. Figured it was something else simple. |
This worked for me!
(Post 11572090)
(Post 11572090)
1st Turn key to on position. 2nd select AM/FM. ⬅️ This the only thing that different from other attempts I was always on aux. Select am/fm and set your clocks 3rd Press & hold clock button and like magic Set Time appears use the 1 though 0 numbers and set time. |
DanW911 ... Also ... Put your complete vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature. *Eliminated the need to play 20 questions when posting. » Edit Signature « *And don't forget to [ save ] it. . |
