1999 v10 performance parts
I have a 1999 F250 with the 6.8L V10 in it and I'm trying to find performance cams and all the topend stuff and I can't seem to find any of it anywhere anyone have any ideas on where I can find the parts I'm looking for
Originally Posted by zakarehamrick
(Post 11555696)
I thought the PI and NPI could use the same cams? whats the difference between the two?
Originally Posted by Ironhand03
(Post 11555828)
Originally Posted by Crazy001
(Post 11555839)
Perhaps they can, I was assuming that the flow differences between the two would necessitate a different cam. :confused:
Almost forgot.
Yes I know where to get all of your top end parts. |
Where at I new then very soon. I dropped a valve need to redo the whole top end and need the truck running ASAP
Do you have an email address so I can send you all the info?
Zakarehamrick@hotmail.comAnd thank u so much
Email sent.
A few technical points:
The '99 has non-PI heads, but PI heads can be bolted on as long as you take care of a few things. 1) Need the PI intake. 2) Compression will go up, somewhere near 10.25:1 if I recall correctly. That needs to be dealt with by using a custom tune. I think Mike at 5-star can help, he did a PI head swap on a '99 V10 already, so he has a baseline to start with. A few other points: No one makes cams for the V10 - Comp Cams I believe used to have blanks that they would machine to your specs, but I don't think they have blanks anymore according to some people here who've tried that route. |
Originally Posted by Krewat
(Post 11563704)
The '99 has non-PI heads, but PI heads can be bolted on as long as you take care of a few things. 1) Need the PI intake. 2) Compression will go up, somewhere near 10.25:1 if I recall correctly. That needs to be dealt with by using a custom tune. I think Mike at 5-star can help, he did a PI head swap on a '99 V10 already, so he has a baseline to start with. A few other points: No one makes cams for the V10 |
Accidental Post!
(Post 11556347)
