Hole in transmission case?
4 Attachment(s)
After driving, i smelled something horrible burning. When I get home, I get on my creeper and roll under to look for anything suspicious, and I find this. It is not where the drain plug in the pan is, it's in front of that. I checked the temp when I was driving but it never got high. It would greatly appreciate any information, I really need my transmission to not explode on me right now, I have a lot of driving to do.
Here's a gallery where there are some pictures, Hopefully someone can tell me what is the problem. It looks like there were threads, and some are left, but it looks like most are gone. Photo Album - Imgur Attachment 294901 Attachment 294902 Attachment 294903 Attachment 294904 |
Hows the fluid leval??
how does the fluid smell?? IDK what went there In that area is where the Torq converter is so I dont think even with the hole you would have lost fluid there |
Fluid levels are all full, no burnt smell. only ever smell burning when i am highway driving, then stop. i checked all brake lines and rotors and pads, nothing out of the ordinary. it doesn't smell like burnt fluid, more like plastic, very strong. but if i drive around town it's fine. it points to the torque converter but when i shoved my nose into that little hole, i did not smell anything.
Originally Posted by JaySVX
(Post 11528148)
Wow, what caused that hole? Almost looks threaded. I had to go crawl under my truck to see. Weird.
The uppper part is threaded, the lower part is not. Looks like there was a plug in there, but it came half out, then "blew out' or got knocked out, pulling the other threads clean. Can anyone check and tell me if they have it?
I do not have that in my tranny case. Should have said that from the git-go.
Nothing like that in mine either just went and look curiosity was getting me no hole bolt just NOTHING in that circle indent
it shouldnt hurt nothing just the TC in there |
Isn't that a inspection point on the transmission? I thought you could knock it out then plug it after the inspection. Of course I could be wrong.
Whatever the reason the hole is there, I can tell it's not supposed to be that way from the factory. Someone, at some point, drilled that hole there for whatever purpose, I couldn't tell you. The only thing that comes to mind, is for access to the torque converter to drain fluid. From the factory, there is no drain plug on the torque coverter, but that doesn't preclude the possibility that someone might have drilled and tapped a plug into it, for access to draining it when needed. Although, that hole does look awfully small for that purpose even.
Might a person be able to "spin" the torque converter, and see if there is an "after market" drain put in?
Originally Posted by amdriven2liv
(Post 11530282)
Yes you can. Put a socket and breaker bar on the front crank sprocket and you can turn the engine. I do it from underneath so I can watch the converter. Leave the trans in park while doing this.
How do you reach the front crank sprocket and be able to see the torque converter?
Even if I can look up the little hole, what am I looking for? |
(Post 11536050)
