Great thread!
Jeff, lovin the thread and the build. My 11 year old son bought a '48 F3 at a local auction back in October. It was a sweet find, $800 a title and very little rust(I am more than a little proud of him). Now we are starting to figure out which way to build it and your info is a big help. I agree with the idea of not puttin any on a card. Did you get all the electonic controls from the engine donor Explorer or are you using one of the install wiring kits on the market? Keep up the great work, it's gonna be awesome. Jeff:)
Originally Posted by jeffsshelbygt
(Post 12737501)
I have an aftermarket wiring harness, from Speedway, for the main wiring of the truck. And I have the engine/computer harness from a 88-93 Mustang. I also have the Explorer harness and two different harnesses from Ford pickups. So I should be able to wire up the truck just about any way I choose! Mustang EEC IV MAF is the way I am going though. Thanks for the compliments! |
Not much going on with wintertime...my ambitions are overridden by cold...it don't like it...but i did order an h-pipe(exhaust) from Summit Racing today.
I think it is my best starting point for an exhaust system. I am using foxbody Mustang 86?-'93 shorty headers. Mustang EEC IV MAF needing 2 Oxygen sensors..one in each bank. So I hope this thing will fit in place like it was meant to be...:-yeahrigh |
Jeff, Are those the header's in your build thread?
Originally Posted by yamagrant
(Post 12822207)
I am ready to do something...I am tired of the cold weather keeping we wussed out... |
5 Attachment(s)
Not to bad of fit for a start!
Hey Jeff,
That looks nice! Are you welding up your own exhaust? You've got some skills. Let's see engine is in, transmission looks in, exhaust on...Hmmmm.. I see driving in your near future. Ben in Austin 1950 F1 |
Looks great Jeff. Do you think those headers would clear the Toyota Box I have in my 56?. I have a buddy with a set he said I could have. I haven't seen them yet but he said they were off a fox bodied mustang.:-X22
Originally Posted by Jeff and Nicolle
(Post 12822562)
Yes Sir Mr YamaGrant! The only set of ceramicoat headers I have ever had.
(Post 12839617)
I wish I could help ya on that! I went through several sets on cast manifolds from different cars and trucks. but nothing fit better than the foxbody shorty's. In my setup. That's the tough part, everyone's setup can be different than the next. They work great in my case! |
Originally Posted by ben73058
(Post 12839251)
Hey Jeff,
That looks nice! Are you welding up your own exhaust? You've got some skills. Let's see engine is in, transmission looks in, exhaust on...Hmmmm.. I see driving in your near future. Ben in Austin 1950 F1 I won't be welding up my own exhaust. This H-pipe is gonna give me a temp. solution to exhaust to get the engine started, whenever that might be... I still have alot of loose ends to take care of on the engine and tranny. And wiring the truck...thats a big loose end! Engine still needs: fuel injector rail installed and fuel lines upper intake and valve covers bolted down. radiator hoses upper and lower oil dipstick front accessories put back on. distributor and wires installed.. Throttle body and linkage and AOD TV cable. Transmission: cooler lines to radiator some external plumbing...minor driveshaft...shocks... and the list goes on and on.... |
Jeff, good to see you working on it again. Looks great! I need to do my exhaust and the rest of your list sounds a lot like mine - except I did the wiring already. Don't be worried about it, it is not as hard as you think. Like putting together a puzzle but with instructions. (assuming you have a kit). The instructions for the Highway 22 that I used needed instructions to read the instructions, but I got through it relatively easy. Keep up the good work, it helps me to keep going because I just don't want to feel left out! :-drink
Originally Posted by topmoo
(Post 12840549)
3 Attachment(s)
Well...inspired by Rockcrln, I got a sheetmetal shrinker/stretcher, a 30" brake, and some 18 gauge cold rolled sheetmetal. I decided to attempt repairing my fenders. Rockcrln..Thank You..!
Starting with a 12"x24" piece. I measured 3/4" and clamped it in the brake. Lesson #1 make sure the clamps are heavy duty and the forming bar doesn't slip when making the bend. |
5 Attachment(s)
Then I make a cut with a die grinder, so a bend can be made for the rear of the fender, where it will mate up with the side of the cab.
