Ford Truck Enthusiasts Forums
-   6.4L Power Stroke Diesel (http://www.ford-trucks.com/forums/forum169/)
-   -   Grease Fittings location (http://www.ford-trucks.com/forums/1142766-grease-fittings-location.html)
chi6488 02-26-2012 09:47 AM
Can someone be nice enough to photo and help me find the grease fittings I need to lube when oil changing??
I cannot find them
UGA33 02-26-2012 03:04 PM
Only grease fittings on these trucks are on 4x4 trucks. There are two. One on each front axle shaft u joint.
longview1 02-26-2012 03:57 PM
^ Didnt think there was any! Ill have to shoot a bit of grease in them two.
senix 02-26-2012 05:02 PM
Confirmed...only the two.
RM2738 08-17-2014 11:18 AM
Been reading a few forums regarding retrofitting Zerks into non serviceable joints in other makes and models. Are there any joints on 2008-2010 SD's that one may consider doing such?
bubbasz1 08-17-2014 09:49 PM
When I had my 2001 F350 I had a vibration after replacing the U Joints in the driveshaft. Ended up taking it to get balanced, they would not touch it unless they replaced the joints with OEM type joints, called the grease-able joints junk, and that was that.
senix 08-18-2014 05:58 AM
I don't think I would touch them till needed. Then replace with grease able joints.
