Adding Aux Input to Factory Radio, Anyone Done?
Has anyone tackled this or heard of anyone doing this? I just saw this company selling a bunch of Ford radios on eBay so it must be fairly easy to do. Here is a link to an example: Ford 1999 2000 2001 2002 2003 2004 Super Duty Radio AM FM CD with IPOD aux input | eBay
Found a Chevy forum that soldered a cable in where the Left and Right channels for the tape deck went on the circuit board. I do have a tape deck that I never use. Wonder if that is possible. Anyone have a wiring schematic for the radio? Here is the link for the Chevy forum: Diy aux input on a factory radio - PerformanceTrucks.net Forums
Have you tried Crutchfield? They sell AUX adapters. Check iPod/iPhone/iPad and USB Adapters
Originally Posted by PaysonPSD
(Post 11477952)
Depending on which radio you have, this article might work for you.
2004 F250 Stereo Upgrade :-drink |
Originally Posted by Shake-N-Bake
(Post 11478018)
(Post 11478018)
Originally Posted by robinsonpowerstroke
(Post 11478000)
No just trying to keep cheap and simple. If not just may buy a new aftermarket head unit.
(Post 11478018)
There are 2 adapter 1 works on 1998 to 2004 Ford radios with a CD button FRDN-AUX
If there is a SAT button you can use the pie frd03-aux/s or frdn-aux/s both will allow you to input perfect clear audio into the original radio |
I have the Crutchfield adapter and it works just fine. I figure no one will want to steal my '01 OEM radio.
someone on the forum has a pretty good writeup modifying their stock stereo to add a $10 aux input jack to their factory radio. I came across it once but didnt save it.
Radio Shack has device you tune into Radio Station for iPod. Cheap too
Originally Posted by jhobbs26
(Post 13567165)
Originally Posted by supra88
(Post 13566888)
If there is a SAT button you can use the pie frd03-aux/s or frdn-aux/s both will allow you to input perfect clear audio into the original radio this is the way to go and they work great. a member here was gracious enough to part with one they were no longer using. it needed some slight repairs, but have been perfect since. FM modulators are ok (and cheap), but they do not provide the crystal clear audio like these adapters. |
