2011 F250 lvl kit/lift plow and rough ride. need advice
I have a 2011 f250 V8 6.2l super cab and i was curious about getting a 2in or 2.5 in leveling kit or maybe lifting it so i can run like 20in rims and some bigger tires but i also plow with it. I live in NJ and plow a couple lots. I was wondering how bad it would be plowing with a leveling kit on or even lifting it a few inches. Also it rides very rough, the roads are horrible around town and anytime i hit a couple pot holes or bumps the truck gets tossed around alot almost uncontrollable at times. Ive brought it back to ford and they made it a little better ive also let air out of the tires and its still bad. Any help or advice would be greatly appreciated. thanks
I have same truck came with 18 s now it has 20 s Ready Lift kit was a pretty easy install , Ride from factory was terrible ,,after lift was just as bad ,,, i Also plow with this truck ,,,Solution a set of Bilstien 5100 shocks and im in heaven should have done this from first day if only i had known ...
Ford F250 Super Duty SST Lift Kit: 2011-2012 4WD Only- 2.5"F/3.A0"R - Stage 3TP Tow |
I've read a lot of posts proclaiming the Bilstien shocks greatly improving the ride....empty. Couple of questions; does it alter the tow capacity, and if I'm not interested in any lift increase are they still am viable option to improved the ride? Lastly, ballpark cost?
Originally Posted by Sargemo105
(Post 11469125)
I paid $299 for my Rancho 9000's, love being able to adjust them for my needs (empty, towing, etc.). |
thanks will deffinatly look into replacing the shocks
