Paint on rear hatch TSB?
After reading on here that several people have had issue with the paint on the rear hatch and the fact that mine looks to be in the same boat, is there a TSB for this? I think the paint has a 5 year warranty if I remember correctly.
Unfortunately the paint warranty I believe is for perforation (rusted through) and since the hatch is aluminum it's not gonna rust :( just have paint coming off in chunks.
Check with your dealer, some will try to push it through as warranty work others will tell you you're out of luck. Try this. It's the only one I could find doing a quick search. 06-25-15***ALUMINUM BODY PANELS - CORROSION - SERVICE TIP Matt |
FMC repainted mine at 32K. I belive they would not have covered anything if it was past original 36K warranty.
07 EL Limited |
