f150 5.0l Crew cab 2012
Hey Guys,
I've been jumping in the 79's Forum for a long time creeping mostly but Making the leap to a 2012 F150 Crew cab 5.0L XLT now i'm reading alot but havent seen anyone really saying what how many KM's they get to a tank? (Sorry Canadian here i can Convert to Miles) Just wondering and is it a 98L tank or running a 136L tank on everyones? :) |
Hey Marko1. You might also try posting this in the 2009+ F-150 forum here:2009+ F150 - Ford Truck Enthusiasts Forums
Lots of the guys with these trucks hang out there and you might have a better chance at a good response there.;) |
My truck
2011 F-150 FX4 Supercab 5.0L V8 3.73 rear end City MPG = 17 (Converted) = 13.8 Liters per 100km Highway MPG = 22.5 (Converted = 10.4 Liters per 100km Avarage Mixed City Highway = 19mpg (Converted) = 12.3 Liters per 100km My truck came standered with the 36gallon gas tank or 136L tank and I can generally go between 630 to 650 miles per tank of gas...Or 1.013 to 1.046KM per 136L of fuel. Hope this helps. I consider this mileage phenomial considering that my truck is a 5500lbs 4X4 V8 gargantuan. But on a side note, I do drive pretty easy to conserve fuel and reduce wear and tear. Anyway, good luck! |
Thanks 640! Exactly what i was hoping to hear from at least 1 person :) I'm Looking at a 2011 now too bit cheaper and Figure same as the 2012 basically anyhow And they are throwing a bunch of stuff on it So that sounds great! I will post what i end up with here for sure!!
Originally Posted by 640 CI Aluminum FORD
(Post 11340243)
My truck
2011 F-150 FX4 Supercab 5.0L V8 3.73 rear end City MPG = 17 (Converted) = 13.8 Liters per 100km Highway MPG = 22.5 (Converted = 10.4 Liters per 100km Avarage Mixed City Highway = 19mpg (Converted) = 12.3 Liters per 100km My truck came standered with the 36gallon gas tank or 136L tank and I can generally go between 630 to 650 miles per tank of gas...Or 1.013 to 1.046KM per 136L of fuel. Hope this helps. I consider this mileage phenomial considering that my truck is a 5500lbs 4X4 V8 gargantuan. But on a side note, I do drive pretty easy to conserve fuel and reduce wear and tear. Anyway, good luck! I have the same configuration besides a supercrew and still on first tank. The best I have seen so far is 16 litres per 100kms. Will it get better for the next tank.it said 835 to empty when I got it. I am wanting to get numbers like yours. Thanks in advance, |
Averaging 19mpg!?!? Wow, wish I saw #'s like that...
640 ci. how do i pm you? those are numbers that i was told i would get as well..haven't yet but still on first tank.
It has been around 15.5-16 litres per 100km which equated to about 750km's That being said, will the truck get better or should i get it looked at? thanks,
(Post 11340243)
My truck
Originally Posted by colemac
(Post 11408892)
It has been around 15.5-16 litres per 100km which equated to about 750km's That being said, will the truck get better or should i get it looked at? thanks, just got fuel tonight, took 123 litres and it says 750 to empty..i was told i would get numbers like you. is it because it was only the first tank of gas i purchased besides the one that came in it when i took delivery of truck? should i take to dealership or is this known from the start? Thank you for your help, |
(Post 11410835)
640ci
just got fuel tonight, took 123 litres and it says 750 to empty..i was told i would get numbers like you. is it because it was only the first tank of gas i purchased besides the one that came in it when i took delivery of truck? should i take to dealership or is this known from the start? Thank you for your help, Appreciate the help from 640 when he gets it :) |
