1965-72 f100 shortbed frames the same?
I'm looking for a better frame for my 1965 f100 2wd shortbed project. I seem to remember it being mentioned here that that the frames from 1965 through 1972 all interchange? If so does that mean the sheetmetal mounting points were the same for all these years? I tried the search section but could'nt find an answer. If they are the same that really expands my possibilities.
Looking for a frame or "non restorable" truck in the Mid Atlantic area. Thanks in advance for your help. Lefty |
You might check with Tom at Flashback F100's located in NC. He saves all the frames from the trucks he parts out.
Flashback F100's - Home |
dont forget.... it will need a title. thats where the VIN is stamped.
They arent the same..different wheelbases...
- cs65 |
Originally Posted by camperspecial65
(Post 11306482)
8' bed: 1965/66: 129" wheelbase / 1967/72: 131" wheelbase. |
72 and 73-79 shortbed wheelbase
Are the 73-79 shortbed wheelbases all the same? What is it?
Originally Posted by 37 Ford guy
(Post 11306698)
'73 F100 shortbed at 117" 1973 FORD F100 Information Specifications Resources Pictures
Thru 1972, the inner frame rails behind the cab are 33 1/2" apart.
1973: Ford widened these rails to 37 1/2" on everything except 1973/77 F250 4WD's (High Boys) and F350's on the 140" wheelbase. |
Bill . . . you're the Man!
Too bad you can't bottle all of that information and sell it. You'd be a rich man (if you're not already). |
Sheet metal mounting points are the same for the cab, and radiator support. Bed will need a possible re drill for mounting.
The frame profile and cab mounts are slightly different as they use differing cab insulators and radiator support pucks. Garbz |
Originally Posted by garbz2
(Post 11983550)
Originally Posted by JadenG19
(Post 19910065)
How difficult are these modifications??
in memoriam - Ford Truck Enthusiasts Forums (ford-trucks.com) |
I found out they only make a S/S brake line kit for a 1966 Ford F-100 and F-150 and I have a 1966 F-250 3/4 ton 2wd with the D81 long bed body .. will the F-100 F-150 long bed brake line kit work for me ?? any help would be greatly appreciated on this matter .. Thanks
Originally Posted by 66f-100
(Post 11305671)
