Help!?!?!? Cant get the snap ring off front hub.
Hello, if you have done ball joints on a 05+ 4wd, where did you get the snap ring pliers that get it out? I have broken two pairs and now have the wife at Sears now with a new snap ring looking for a set there. Since I have a new snap ring, I am willing to break it to get it out, but I still gotta get the new one in. Besides that it is a heafty ring, who knows if I can cut it, or even bend it. There is a plastic lip that I am worried about breaking. I can get it open enough that I can get a screwdriver in between the ring and the plastic. I am hoping someone has a trick. Or knows if a big box store has a pair that will work. Thanks
It's not that stiff of a ring. Maybe spray some WD-40 or penetrating oil around the snap ring in case it's just seized in place. Take your new snap ring pliers the wife brings home and use them on your new snap ring. You'll see it's not the stiffness of the snap ring that is causing your problems.
It not siezed, I can spin it while opening it. I think the snap ring was changed after the 05 model year. Mine is almost 1/8th inch thick.
Originally Posted by run6.0run
(Post 11300698)
Are you talking about the ball joint snap ring or the snap ring on the axle? |
Sorry about that, but yes the snap ring on the axle>>>
That one is a bugger. I ended up getting a snap ring pliers from Napa that worked well for mine. Use a pry bar and pull the axle towards the hub to get more clearance to remove it and install the snap ring.
Do you have the knuckle seal driver tool?
I got a 12" peice of 1 1/4 pipe with the floor flange and a cap,(and my grinder). I would like to run down what I have. The tools are, ball joint press, pitman arm puller, big 3 jaw puller, and the ole trusty toolbox(es). I have a big seal (national part #710493), small seal (national part #710413), the 4wd hub service kit (fomoco #5C3Z-1K106-AB), and the ball joints. I am needing to do the ball joints (and check the bearings and the ujoint at the wheel). I saw somewhere on here that the channelock 927 8 inch retaining ring pliers have worked for others. It looks like home depot has em. I have a great tool place here in Blue Springs MO called Clarks Tool, so if someone has any better tool to remove the snap ring at the hub, then I would be greatly appreciative of that info. This is the first issue I have had with the front end, sure can't wait to get one under my belt. I also just did my gluw plugs and wires and replaced the front driveshaft (it was bent). This is gettin expensive, so I can't wait to get it done.
I am also wondering what the camber adjusting sleeve is. I should get the snap ring out tomorrow and after reading up on the procedure, the only thing I have no idea about is what the camber adjusting sleeve is, or what it looks like or any info on it. I really dont want to get it apart and find out I messed up with the sleeve. Is it on the top or bottom of the knuckle? Or does it serve as a bushing that goes inside the hole in the knuckle? Im full of questions, thanks for all the input.
The alignment sleeve is in the top ball joint, you really can't miss it because it's the sleeve looking deal sticking down into the joint under the castle nut. In the past I've used a brass hammer to knock on knuckles to get the ball joints to separate, emphasis on brass and not steel.
These are alignment sleeves: https://www.ford-trucks.com/forums/p...ictureid=40171 It's the rust colored thing under the castle nut in this pic: https://www.ford-trucks.com/forums/p...ictureid=23658 |
(Post 11301676)
I can get you a picture of the pliers I used if that helps. |
thanks for the info on the sleeves Texas. As for the tool, YES PLEASE, I would love a pic. I have the channellock 927's and the only way they will even reach the ring is if I overextend the tips, which causes them to bend. I just got a fat pair of snap ring pliers from a tool store locally, but they are too big. I am about to weld the tips from the big set of pliers onto a set of long ring pliers. I hope it works. i am trying to find a quick way to post pics from my phone to here.
You are using a pliers with the interchangeable tips?
yes, but I couldnt get those to work. I finally got it out using a set that I made. Im having a heck of a time getting the outer seal out. I read up all I could,,,, but this is an 06. All of the reading was apparaently for a 04 and earlier. I have the hub off and now Im working on the seal. Mistercmk, any pointers??????????? I have been hitting the small lip on the inside, and have been prying on the axle at the lip for the inner seal. Do I just need to keep at it, or am I missing something?
You're talking about the knuckle seal, right?
