6.7 DTC (Diagnostic Trouble Codes)
P0001 - Fuel Volume Regulator Control Circuit
P0002 - Fuel Volume Regulator Control Circuit Range/Performance P0003 - Fuel Volume Regulator Control Circuit Low P0004 - Fuel Volume Regulator Control Circuit High P000E - Fuel Volume Regulator Control Exceeded Learning Limit I don't know if these have been posted but here they are. P0016 - Crankshaft Position - Camshaft Position Correlation - Bank 1 Sensor A P0069 - MAP - Barometric Pressure Correlation P006B - MAP/Exhaust Pressure Correlation P006D - Barometric Pressure - Turbocharger/Supercharger Inlet Pressure Correlation P0070 - Ambient Air Temperature Sensor Circuit P0071 - Ambient Air Temperature Sensor Range/Performance P0072 - Ambient Air Temperature Sensor Circuit Low P0073 - Ambient Air Temperature Sensor Circuit High P007B - Charge Air Cooler Temperature Sensor Circuit Range/Performance (Bank 1) P007C - Charge Air Cooler Temperature Sensor Circuit Low (Bank 1) P007D - Charge Air Cooler Temperature Sensor Circuit High (Bank 1) P0087 - Fuel Rail/System Pressure - Too Low P0088 - Fuel Rail/System Pressure - Too High P0089 - Fuel Pressure Regulator Performance P008A - Low Pressure Fuel System Pressure - Too Low P008C - Fuel Cooler Pump Control Circuit/Open P008D - Fuel Cooler Pump Control Circuit Low P008E - Fuel Cooler Pump Control Circuit High P008F - Engine Coolant Temperature/Fuel Temperature Correlation P0090 - Fuel Pressure Regulator Control Circuit P0091 - Fuel Pressure Regulator Control Circuit Low P0092 - Fuel Pressure Regulator Control Circuit High P0093 - Fuel System Leak Detected - Large Leak P0096 - Intake Air Temperature Sensor 2 Circuit Range/Performance P0097 - Intake Air Temperature Sensor 2 Circuit Low P0098 - Intake Air Temperature Sensor 2 Circuit High P009A - Intake Air Temperature /Ambient Air Temperature Correlation P00BC - Mass or Volume Air Flow A Circuit Range/Performance - Air Flow Too Low P00BD - Mass or Volume Air Flow A Circuit Range/Performance - Air Flow Too High P0100 - Mass Or Volume Air Flow A Circuit P0101 - Mass or Volume Air Flow A Circuit Range/Performance P0102 - Mass or Volume Air Flow A Circuit Low P0103 - Mass or Volume Air Flow A Circuit High P0104 - Mass or Volume Air Flow A Circuit Intermittent/Erratic P0106 - Manifold Absolute Pressure (MAP/BARO) Sensor Range/Performance P0107 - Manifold Absolute Pressure (MAP)/Barometric Pressure (BARO) Sensor Low P0108 - Manifold Absolute Pressure (MAP)/Barometric Pressure (BARO) Sensor High P0111 - Intake Air Temperature (IAT) Sensor 1 Circuit Range/Performance P0112 - Intake Air Temperature (IAT) Sensor 1 Circuit Low P0112 - Intake Air Temperature (IAT) Sensor 1 Circuit Low P0113 - Intake Air Temperature (IAT) Sensor 1 Circuit High P0113 - Intake Air Temperature (IAT) Sensor 1 Circuit High P0114 - Intake Air Temperature (IAT) Sensor 1 Intermittent/Erratic P0115 - Engine Coolant Temperature Sensor 1 Circuit P0116 - Engine Coolant Temperature Sensor 1 Circuit Range/Performance P0117 - Engine Coolant Temperature Sensor 1 Circuit Low P0118 - Engine Coolant Temperature Sensor 1 Circuit High P0128 - Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature) P012F - Engine Coolant Temperature / Engine Oil Temperature Correlation P0133 - O2 Sensor Circuit Slow Response (Bank1 Sensor 1) P0134 - O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1) P0148 - Fuel Delivery Error P0149 - Fuel Timing Error P0168 - Engine Fuel Temperature Too High P016B - Closed Loop Air/Fuel Ratio Control at Limit - System Too Rich P016C - Closed Loop Air/Fuel Ratio Control at Limit - System Too Lean P016D - Excessive Time to Enter Closed Loop Fuel Pressure Control P0181 - Fuel Temperature Sensor A Circuit Range/Performance P0182 - Fuel Temperature Sensor A Circuit Low P0183 - Fuel Temperature Sensor A Circuit High P0191 - Fuel Rail Pressure Sensor A Circuit Range/Performance P0192 - Fuel Rail Pressure Sensor A Circuit Low P0193 - Fuel Rail Pressure Sensor A Circuit High P0194 - Fuel Rail Pressure Sensor A Circuit Intermittent/Erratic P0195 - Engine Oil Temperature Sensor Circuit P0196 - Engine Oil Temperature Sensor Circuit Range/Performance P0197 - Engine Oil Temperature Sensor Circuit Low P0198 - Engine Oil Temperature Sensor Circuit High P0201 - Injector Circuit/Open - Cylinder 1 P0202 - Injector Circuit/Open - Cylinder 2 P0203 - Injector Circuit/Open - Cylinder 3 P0204 - Injector Circuit/Open - Cylinder 4 P0205 - Injector Circuit/Open - Cylinder 5 P0206 - Injector Circuit/Open - Cylinder 6 P0207 - Injector Circuit/Open - Cylinder 7 P0208 - Injector Circuit/Open - Cylinder 8 P0216 - Injector/Injection Timing Control Circuit P0219 - Engine Overspeed Condition P0231 - Fuel Pump Secondary Circuit Low P0232 - Fuel Pump Secondary Circuit High P0234 - Turbocharger/Supercharger A Overboost Condition P0243 - Turbocharger/Supercharger Wastegate Solenoid A P0245 - Turbocharger/Supercharger Wastegate Solenoid A Low P0246 - Turbocharger/Supercharger Wastegate Solenoid A High P0263 - Cylinder 1 Contribution/Balance P0266 - Cylinder 2 Contribution/Balance P0269 - Cylinder 3 Contribution/Balance P026A - Charge Air Cooler Efficiency Below Threshold P0272 - Cylinder 4 Contribution/Balance P0275 - Cylinder 5 Contribution/Balance P0278 - Cylinder 6 Contribution/Balance P0281 - Cylinder 7 Contribution/Balance P0284 - Cylinder 8 Contribution/Balance P0297 - Vehicle Overspeed Condition P0298 - Engine Oil Overtemperature Condition P0299 - Turbocharger/Supercharger A Underboost Condition P02CC - Cylinder 1 Fuel Injector Offset Learning at Minimum Limit P02CD - Cylinder 1 Fuel Injector Offset Learning at Maximum Limit P02CE - Cylinder 2 Fuel Injector Offset Learning at Minimum Limit P02CF - Cylinder 2 Fuel Injector Offset Learning at Maximum Limit P02D0 - Cylinder 3 Fuel Injector Offset Learning at Minimum Limit P02D1 - Cylinder 3 Fuel Injector Offset Learning at Maximum Limit P02D2 - Cylinder 4 Fuel Injector Offset Learning at Minimum Limit P02D3 - Cylinder 4 Fuel Injector Offset Learning at Maximum Limit P02D4 - Cylinder 5 Fuel Injector Offset Learning at Minimum Limit P02D5 - Cylinder 5 Fuel Injector Offset Learning at Maximum Limit P02D6 - Cylinder 6 Fuel Injector Offset Learning at Minimum Limit P02D7 - Cylinder 6 Fuel Injector Offset Learning at Maximum Limit P02D8 - Cylinder 7 Fuel Injector Offset Learning at Minimum Limit P02D9 - Cylinder 7 Fuel Injector Offset Learning at Maximum Limit P02DA - Cylinder 8 Fuel Injector Offset Learning at Minimum Limit P02DB - Cylinder 8 Fuel Injector Offset Learning at Maximum Limit P02E0 - Diesel Intake Air Flow Control Circuit/Open P02E1 - Diesel Intake Air Flow Control Performance P02E2 - Diesel Intake Air Flow Control Circuit Low P02E3 - Diesel Intake Air Flow Control Circuit High P02E8 - Diesel Intake Air Flow Position Sensor Circuit Low P02E9 - Diesel Intake Air Flow Position Sensor Circuit High P02EC - Diesel Intake Airflow Control System - High Airflow Detected P02ED - Diesel Intake Airflow Control System - Low Airflow Detected P02EE - Cylinder 1 Injector Circuit Range/Performance P02EF - Cylinder 2 Injector Circuit Range/Performance P02F0 - Cylinder 3 Injector Circuit Range/Performance P02F1 - Cylinder 4 Injector Circuit Range/Performance P02F2 - Cylinder 5 Injector Circuit Range/Performance P02F3 - Cylinder 6 Injector Circuit Range/Performance P02F4 - Cylinder 7 Injector Circuit Range/Performance P02F5 - Cylinder 8 Injector Circuit Range/Performance P0300 - Random Misfire Detected P0301 - Cylinder 1 Misfire Detected P0302 - Cylinder 2 Misfire Detected P0303 - Cylinder 3 Misfire Detected P0304 - Cylinder 4 Misfire Detected P0305 - Cylinder 5 Misfire Detected P0306 - Cylinder 6 Misfire Detected P0307 - Cylinder 7 Misfire Detected P0308 - Cylinder 8 Misfire Detected P0315 - Crankshaft Position System Variation Not Learned P0335 - Crankshaft Position Sensor A Circuit P0336 - Crankshaft Position Sensor A Circuit Range/Performance P0337 - Crankshaft Position Sensor A Circuit Low P0340 - Camshaft Position Sensor A Circuit (Bank 1 or single sensor) P0341 - Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or Single Sensor) P0342 - Camshaft Position Sensor A Circuit Low (Bank 1 or Single Sensor) P0381 - Glow Plug/Heater Indicator Circuit P0401 - Exhaust Gas Recirculation (EGR) Flow Insufficient Detected P0402 - Exhaust Gas Recirculation (EGR) Flow Excessive Detected P0403 - Exhaust Gas Recirculation (EGR) Control Circuit P0404 - Exhaust Gas Recirculation (EGR) Control Circuit Range/Performance P0405 - Exhaust Gas Recirculation (EGR) Sensor A Circuit Low P0406 - Exhaust Gas Recirculation (EGR) Sensor A Circuit High P040B - Exhaust Gas Recirculation Temperature (EGRT) Sensor A Circuit Range/Performance P040B - Exhaust Gas Recirculation Temperature (EGRT) Sensor A Circuit Range/Performance P040C - Exhaust Gas Recirculation Temperature (EGRT) Sensor A Circuit Low P040D - Exhaust Gas Recirculation Temperature (EGRT) Sensor A Circuit High P041B - Exhaust Gas Recirculation Temperature (EGRT) Sensor B Circuit Range/Performance P041C - Exhaust Gas Recirculation Temperature (EGRT) Sensor B Circuit Low P041D - Exhaust Gas Recirculation Temperature (EGRT) Sensor B Circuit High P0420 - Catalyst System Efficiency Below Threshold (Bank 1) P042E - Exhaust Gas Recirculation (EGR) Control Stuck Open P042F - Exhaust Gas Recirculation (EGR) Control Stuck Closed P0471 - Exhaust Pressure Sensor A Circuit Range/Performance P0472 - Exhaust Pressure Sensor A Circuit Low P0473 - Exhaust Pressure Sensor A Circuit High P0480 - Fan 1 Control Circuit P0483 - Fan Performance P0488 - Exhaust Gas Recirculation (EGR) Throttle Control Circuit A Range/Performance P0489 - Exhaust Gas Recirculation (EGR) A Control Circuit Low P0490 - Exhaust Gas Recirculation (EGR) A Control Circuit High P0494 - Fan Speed Low P0495 - Fan Speed High P04D9 - Closed Loop EGR Control at Limit - Flow Too Low P04DA - Closed Loop EGR Control at Limit - Flow Too High P0500 - Vehicle Speed Sensor A P0503 - Vehicle Speed Sensor (VSS) A Intermittent/Erratic/High P0504 - Brake Switch A / B Correlation P0506 - Idle Air Control System RPM Lower Than Expected P0507 - Idle Air Control System RPM Higher Than Expected P050E - Cold Start Engine Exhaust Temperature Too Low P0512 - Starter Request Circuit P0528 - Fan Speed Sensor Circuit No Signal P0529 - Fan Speed Sensor Circuit Intermittent P0544 - Exhaust Gas Temperature Sensor Circuit - Bank 1 Sensor 1 P0545 - Exhaust Gas Temperature Sensor Circuit Low - Bank 1 Sensor 1 P0546 - Exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 1 P054E - Idle Control System - Fuel Quantity Lower Than Expected P054F - Idle Control System - Fuel Quantity Higher Than Expected P0560 - System Voltage P0562 - System Voltage Low P0563 - System Voltage High P0565 - Cruise Control ON Signal P0566 - Cruise Control OFF Signal P0567 - Cruise Control RESUME Signal P0568 - Cruise Control SET Signal P0569 - Cruise Control COAST Signal P0571 - Brake Switch A Circuit P0572 - Brake Switch A Circuit Low P0573 - Brake Switch A Circuit High P0600 - Serial Communication Link P0601 - Internal Control Module Memory Checksum Error P0602 - Powertrain Control Module (PCM) Programming Error P0603 - Internal Control Module Keep Alive Memory (KAM) Error P0604 - Internal Control Module Random Access Memory (RAM) Error P0605 - Internal Control Module Read Only Memory (ROM) Error P0606 - Control Module Processor P0607 - Control Module Performance P060A - Internal Control Module Monitoring Processor Performance P060B - Internal Control Module A/D Processing Performance P060C - Internal Control Module Main Processor Performance P060D - Internal Control Module Accelerator Pedal Position Performance P0610 - Control Module Vehicle Options Error P0611 - Fuel Injector Control Module Performance P061A - Internal Control Module Torque Performance P061B - Internal Control Module Torque Calculation Performance P061C - Internal Control Module Engine RPM Performance P0620 - Generator Control Circuit P0625 - Generator Field Terminal Circuit Low P0626 - Generator Field Terminal Circuit High P0627 - Fuel Pump A Control Circuit/Open P0628 - Fuel Pump A Control Circuit Low P0629 - Fuel Pump A Control Circuit High P062A - Fuel Pump A Control Circuit Range/Performance P062B - Internal Control Module Fuel Injector Control Performance P062D - Fuel Injector Driver Circuit Performance Bank 1 P062E - Fuel Injector Driver Circuit Performance Bank 2 P062F - Internal Control Module EEPROM Error P0642 - Sensor Reference Voltage A Circuit Low P0643 - Sensor Reference Voltage A Circuit High P0645 - A/C Clutch Relay Control Circuit P0646 - A/C Clutch Relay Control Circuit Low P0647 - A/C Clutch Relay Control Circuit High P064C - Glow Plug Control Module P0652 - Sensor Reference Voltage B Circuit Low P0653 - Sensor Reference Voltage B Circuit High P066A - Cylinder 1 Glow Plug Circuit Low P066B - Cylinder 1 Glow Plug Circuit High P066C - Cylinder 2 Glow Plug Circuit Low P066D - Cylinder 2 Glow Plug Circuit High P066E - Cylinder 3 Glow Plug Circuit Low P066F - Cylinder 3 Glow Plug Circuit High P0670 - Glow Plug Control Module (GPCM) Control Circuit/Open P0671 - Cylinder 1 Glow Plug Circuit/Open P0672 - Cylinder 2 Glow Plug Circuit/Open P0673 - Cylinder 3 Glow Plug Circuit/Open P0674 - Cylinder 4 Glow Plug Circuit/Open P0675 - Cylinder 5 Glow Plug Circuit/Open P0676 - Cylinder 6 Glow Plug Circuit/Open P0677 - Cylinder 7 Glow Plug Circuit/Open P0678 - Cylinder 8 Glow Plug Circuit/Open P067A - Cylinder 4 Glow Plug Circuit Low P067B - Cylinder 4 Glow Plug Circuit High P067C - Cylinder 5 Glow Plug Circuit Low P067D - Cylinder 5 Glow Plug Circuit High P067E - Cylinder 6 Glow Plug Circuit Low P067F - Cylinder 6 Glow Plug Circuit High P0684 - Glow Plug Control Module (GPCM) to Powertrain Control Module (PCM) Communication Circuit Range/Performance P0685 - ECM/PCM Power Relay Control Circuit/Open P068A - ECM/PCM Power Relay De-Energized - Too Early P068C - Cylinder 7 Glow Plug Circuit Low P068D - Cylinder 7 Glow Plug Circuit High P068E - Cylinder 8 Glow Plug Circuit Low P068F - Cylinder 8 Glow Plug Circuit High P0691 - Fan 1 Control Circuit Low P0692 - Fan 1 Control Circuit High P06A6 - Sensor Reference Voltage A Circuit Range/Performance P06A7 - Sensor Reference Voltage B Circuit Range/Performance P06A8 - Sensor Reference Voltage C Circuit Range/Performance P06B9 - Cylinder 1 Glow Plug Circuit Range/Performance P06BA - Cylinder 2 Glow Plug Circuit Range/Performance P06BB - Cylinder 3 Glow Plug Circuit Range/Performance P06BC - Cylinder 4 Glow Plug Circuit Range/Performance P06BD - Cylinder 5 Glow Plug Circuit Range/Performance P06BE - Cylinder 6 Glow Plug Circuit Range/Performance P06BF - Cylinder 7 Glow Plug Circuit Range/Performance P06C0 - Cylinder 8 Glow Plug Circuit Range/Performance P06DF - Glow Plug Control Module (GPCM) Memory Checksum Error P06EA - NOx Sensor Processor Performance (Bank 1 Sensor 1) P0703 - Brake Switch B Input Circuit P0704 - Clutch Switch Input Circuit P0A09 - DC/DC Converter Status Circuit Low P0A10 - DC/DC Converter Status Circuit High P1000 - On-Board Diagnostic (OBD) Systems Readiness Test Not Complete P1100 - Mass Air Flow (MAF) Sensor Circuit Intermittent P1102 - Mass Air Flow Sensor In Range But Lower Than Expected P1103 - Mass Air Flow Sensor In Range But Higher Than Expected P1111 - System Pass P1116 - Engine Coolant Temperature (ECT) Sensor Out of Self-Test Range P1140 - Water in Fuel Condition P115A - Low Fuel Level - Forced Limited Power P117B - Exhaust Gas Temperature Sensor Correlation - Bank 1 P117F - Fuel Pressure Regulator Control Exceeded Learning Limits P1184 - Engine Oil Temperature Sensor Out Of Self-Test Range P1184 - Engine Oil Temperature (EOT) Sensor Out of Self-Test Range P1201 - Cylinder 1 Injector Circuit Open/Shorted P1202 - Cylinder 2 Injector Circuit Open/Shorted P1203 - Cylinder 3 Injector Circuit Open/Shorted P1204 - Cylinder 4 Injector Circuit Open/Shorted P1205 - Cylinder 5 Injector Circuit Open/Shorted P1206 - Cylinder 6 Injector Circuit Open/Shorted P1207 - Cylinder 7 Injector Circuit Open/Shorted P1208 - Cylinder 8 Injector Circuit Open/Shorted P120F - Fuel Pressure Regulator Excessive Variation P123C - Cold Start Turbo Protection - Forced Limited Power P1247 - Turbocharger Boost Pressure Low P1249 - Wastegate Control Valve Performance P1260 - Theft Detected, Vehicle Immobilized P1261 - Cylinder 1 High To Low Side Short P1262 - Cylinder 2 High To Low Side Short P1263 - Cylinder 3 High To Low Side Short P1264 - Cylinder 4 High To Low Side Short P1265 - Cylinder 5 High To Low Side Short P1266 - Cylinder 6 High To Low Side Short P1267 - Cylinder 7 High To Low Side Short P1268 - Cylinder 8 High To Low Side Short P127A - Aborted KOER - Fuel Pressure Failure P127A - Aborted KOER - Fuel Pressure Failure P1291 - Injector High Side Short To GND Or VBATT - Bank 1 P1292 - Injector High Side Short To GND Or VBATT - Bank 2 P132A - Turbocharger/Supercharger Boost Control A Electrical P132B - Turbocharger/Supercharger Boost Control A Performance P132C - Turbocharger/Supercharger Boost Control A Voltage P1335 - Exhaust Gas Recirculation (EGR) Position Sensor Minimum/Maximum Stop Performance P1336 - Crankshaft/Camshaft Sensor Range/Performance P138B - Glow Plug Control Module System Voltage P138D - Turbocharger Boost Control A Temperature Too High P1397 - System Voltage Out Of Self-Test Range P1397 - System Voltage Out Of Self Test Range P1408 - Exhaust Gas Recirculation (EGR) Flow Out Of Self-Test Range P1408 - Exhaust Gas Recirculation (EGR) Flow Out Of Self-Test Range P145B - A/C Demand Not Activated During Self-Test P1464 - A/C Demand Out Of Self-Test Range P1501 - Vehicle Speed Sensor Out Of Self-Test Range P1501 - Vehicle Speed Sensor Out Of Self Test Range P1531 - Invalid Test - Accelerator Pedal Movement P1536 - Parking Brake Switch Circuit P1548 - Engine Air Filter Restriction P1551 - Cylinder 1 Injector Circuit Range/Performance P1552 - Cylinder 2 Injector Circuit Range/Performance P1553 - Cylinder 3 Injector Circuit Range/Performance P1554 - Cylinder 4 Injector Circuit Range/Performance P1555 - Cylinder 5 Injector Circuit Range/Performance P1556 - Cylinder 6 Injector Circuit Range/Performance P1557 - Cylinder 7 Injector Circuit Range/Performance P1558 - Cylinder 8 Injector Circuit Range/Performance P1561 - Brake Line Pressure Sensor Circuit P1575 - Pedal Position Out Of Self Test Range P1586 - Electronic Throttle to PCM Communication Error P160C - Control Module Software Performance P161A - Incorrect Response from Immobilizer Control Module P162E - Internal Control Module PTO Performance P1635 - Tire/Axle Out Of Acceptable Range P1639 - Vehicle ID Block Corrupted, Not Programmed P164A - O2 Sensor Positive Current Trim Circuit Performance (Bank 1 Sensor 1) P167F - Non-OEM Calibration Detected P1703 - Brake Switch Out Of Self-Test Range P1705 - Transmission Range Circuit Not Indicating Park/Neutral During Self-Test P1709 - Park/Neutral Position (PNP) Switch Out of Self Test Range P1725 - Insufficient Engine Speed Increase During Self-Test P1726 - Insufficient Engine Speed Decrease During Self-Test P174E - Output Shaft Speed / ABS Wheel Speed Correlation P179A - Controller Area Network (CAN) Engine Control Module (ECM)/Turbocharger Boost Control A Actuator Circuit Malfunction P2002 - Diesel Particulate Filter Efficiency Below Threshold (Bank 1) P200C - Diesel Particulate Filter Over Temperature Bank 1 P200E - Catalyst System Over Temperature (Bank 1) P202D - Reductant Leakage P2031 - Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 2 P2032 - Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 2 P2033 - Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 2 P203A - Reductant Level Sensor A Circuit P203B - Reductant Level Sensor Circuit Range/Performance P203C - Reductant Level Sensor Circuit Low P203D - Reductant Level Sensor Circuit High P203F - Reductant Level Too Low P2043 - Reductant Temperature Sensor Circuit Range/Performance P2047 - Reductant Injection Valve Circuit/Open Bank 1 Unit 1 P2048 - Reductant Injection Valve Circuit Low (Bank 1 Unit 1) P2049 - Reductant Injection Valve Circuit High (Bank 1 Unit 1) P204B - Reductant Pressure Sensor Circuit Range/Performance P204C - Reductant Pressure Sensor Circuit Low P204D - Reductant Pressure Sensor Circuit High P204F - Reductant System Performance (Bank 1) P205C - Reductant Tank Temperature Sensor Circuit Low P205D - Reductant Tank Temperature Sensor Circuit High P2073 - Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Idle P2074 - Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher Load P207F - Reductant Quality Performance P2080 - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 1 P2081 - Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 1 P2084 - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 2 P2085 - Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 2 P208A - Reductant Pump Control Circuit Open Load P208B - Reductant Pump A Control Range/Performance P208C - Reductant Pump Control Circuit Low P208D - Reductant Pump Control Circuit High P208E - Reductant Injection Valve Stuck Closed (Bank 1 Unit 1) P209F - Reductant Tank Heater Control Performance P20A0 - Reductant Purge Control Valve Circuit Open Load P20A1 - Reductant Purge Control Valve Performance P20A2 - Reductant Purge Control Valve Circuit Low P20A3 - Reductant Purge Control Valve Circuit High P20B9 - Reductant Heater A Control Circuit/Open P20BA - Reductant Heater A Control Performance P20BB - Reductant Heater A Control Circuit Low P20BC - Reductant Heater A Control Circuit High P20BD - Reductant Heater B Control Circuit/Open P20BE - Reductant Heater B Control Performance P20BF - Reductant Heater B Control Circuit Low P20C0 - Reductant Heater B Control Circuit High P20C1 - Reductant Heater C Control Circuit/Open P20C2 - Reductant Heater C Control Performance P20C3 - Reductant Heater C Control Circuit Low P20C4 - Reductant Heater C Control Circuit High P20E2 - Exhaust Gas Temperature Sensor 1/2 Correlation Bank 1 P20E3 - Exhaust Gas Temperature Sensor 1/3 Correlation Bank 1 P20E4 - Exhaust Gas Temperature Sensor 2/3 Correlation Bank 1 P20E8 - Reductant Pressure Too Low P20E9 - Reductant Pressure Too High P20EE - SCR NOx Catalyst Efficiency Below Threshold (Bank 1) P2122 - Throttle/Pedal Position Sensor/Switch D Circuit Low P2123 - Throttle/Pedal Position Sensor/Switch D Circuit High P2127 - Throttle/Pedal Position Sensor/Switch E Circuit Low P2128 - Throttle/Pedal Position Sensor/Switch E Circuit High P2138 - Throttle/Pedal Position Sensor/Switch D/E Voltage Correlation P215A - Vehicle Speed / Wheel Speed Correlation P215B - Vehicle Speed / Output Shaft Speed Correlation P2182 - Engine Coolant Temperature Sensor 2 Circuit P2183 - Engine Coolant Temperature Sensor 2 Circuit Range/Performance P2184 - Engine Coolant Temperature Sensor 2 Circuit Low P2185 - Engine Coolant Temperature Sensor 2 Circuit High P2199 - Intake Air Temperature (IAT) 1/2 Correlation P21AB - Reductant Level Sensor B Circuit High P21B0 - Reductant Level Sensor C Circuit High P2200 - NOx Sensor Circuit (Bank 1 Sensor 1) P2201 - NOx Sensor Circuit Range/Performance Bank 1 P2209 - NOx Sensor Heater Sense Circuit Range/Performance (Bank 1 Sensor 1) P220A - NOx Sensor Supply Voltage Circuit (Bank 1 Sensor 1) P220E - NOx Sensor Heater Control Circuit Range/Performance (Bank 1 Sensor 1) P2227 - Barometric Pressure Sensor A Circuit Range/Performance P2228 - Barometric Pressure Circuit Low P2229 - Barometric Pressure Circuit High P2230 - Barometric Pressure Circuit Intermittent P225A - NOx Sensor Calibration Memory (Bank 1 Sensor 1) P2262 - Turbo/Super Charger Boost Pressure Not Detected - Mechanical P2263 - Turbo/Super Charger Boost System Performance P2269 - Water in Fuel Condition P2289 - Injector Control Pressure Too High - Engine Off P228E - Fuel Pressure Regulator 1 Exceeded Learning Limits - Too Low P228F - Fuel Pressure Regulator 1 Exceeded Learning Limits - Too High P2291 - Injector Control Pressure Too Low - Engine Cranking P2425 - Exhaust Gas Recirculation Cooling Valve Control Circuit/Open P2426 - Exhaust Gas Recirculation Cooling Valve Control Circuit Low P2427 - Exhaust Gas Recirculation Cooling Valve Control Circuit High P242A - Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 3 P242B - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 3 P242C - Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 3 P242D - Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 3 P242E - Exhaust Gas Temperature Sensor Circuit Intermittent/Erratic Bank 1 Sensor 3 P242F - Diesel Particulate Filter Restriction - Ash Accumulation P244A - Diesel Particulate Filter Differential Pressure Too Low P244C - Exhaust Temperature Too Low For Particulate Filter Regeneration, Bank 1 P244D - Exhaust Temperature Too High For Particulate Filter Regeneration, Bank 1 P2452 - Diesel Particulate Filter Pressure Sensor A Circuit P2452 - Diesel Particulate Filter Pressure Sensor A Circuit P2453 - Diesel Particulate Filter Pressure Sensor A Circuit Range/Performance P2454 - Diesel Particulate Filter Pressure Sensor A Circuit Low P2455 - Diesel Particulate Filter Pressure Sensor A Circuit High P2456 - Diesel Particulate Filter Pressure Sensor A Circuit Intermittent/Erratic P2457 - Exhaust Gas Recirculation (EGR) Cooler System Performance P2458 - Diesel Particulate Filter Regeneration Duration P2459 - Diesel Particulate Filter Regeneration Frequency P2463 - Diesel Particulate Filter - Soot Accumulation P246C - Diesel Particulate Filter Restriction - Forced Limited Power P246E - Exhaust Gas Temperature Sensor Circuit (Bank 1 Sensor 4) P2470 - Exhaust Gas Temperature Sensor Circuit Low (Bank 1 Sensor 4) P2471 - Exhaust Gas Temperature Sensor Circuit High (Bank 1 Sensor 4) P2478 - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 1) P2479 - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 2) P247A - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 3) P247B - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 4) P249C - SCR Time to Closed Loop P249D - Closed Loop Reductant Injection Control At Limit - Flow Too Low P249E - Closed Loop Reductant Injection Control At Limit - Flow Too High P249F - Excessive Time To Enter Closed Loop DPF Regeneration Control P24A0 - Closed Loop DPF Regeneration Control At Limit - Temperature Too Low P24A2 - Diesel Particulate Filter Regeneration Incomplete P24A5 - Exhaust Gas Recirculation (EGR) Cooler Bypass Control Stuck (Bank 1) P2506 - ECM / PCM Power Input Signal Range/Performance P2507 - ECM / PCM Power Input Signal Low P2508 - ECM / PCM Power Input Signal High P2545 - Torque Management Request Input Signal A Range / Performance P2560 - Engine Coolant Level Low P2563 - Turbocharger Boost Control Position Sensor A Circuit Range/Performance P2610 - Electronic Control Module (ECM)/Powertrain Control Module (PCM) Internal Engine Off Timer Performance P262A - Fuel Injector - Pilot Injection Not Learned P268C - Cylinder 1 Injector Data Incompatible P268D - Cylinder 2 Injector Data Incompatible P268E - Cylinder 3 Injector Data Incompatible P268F - Cylinder 4 Injector Data Incompatible P2690 - Cylinder 5 Injector Data Incompatible P2691 - Cylinder 6 Injector Data Incompatible P2692 - Cylinder 7 Injector Data Incompatible P2693 - Cylinder 8 Injector Data Incompatible P2A00 - O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) P2BA7 - NOx Exceedence - Empty Reagent Tank U0073 - Control Module Communication Bus A Off U0074 - Control Module Communication Bus B Off U0101 - Lost Communication With Transmission Control Module (TCM) U0106 - Lost Communication With GPCM U0121 - Lost Communication With The Anti-lock Brake System (ABS) Control Module U0137 - Lost Communication With Trailer Brake Control (TBC) Module U0140 - Lost Communication With Body Control Module U0151 - Lost Communication With Restraints Control Module (RCM) U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module U0212 - Lost Communication With Steering Column Control Module U029D - Lost Communication With NOx Sensor A U0307 - Software Incompatibility with GPCM U0402 - Invalid Data Received from Transmission Control Module (TCM) U0407 - Invalid Data Received From GPCM U0418 - Invalid Data Received From Brake System Control Module U041E - Invalid Data Received From All Wheel Drive Control Module U0452 - Invalid Data Received From Restraints Control Module U059E - Invalid Data Received from NOx Sensor A U05A1 - NOx Sensor A Received Invalid Data From ECM/PCM |
Wow! Sure hope that was a copy/paste. :D
Nice info. I bet that finds it's way into the tech folder. :-X22 |
It needs to for sure :)
The tech folder has a spot for a DTC list but no list. Can we get a mod to move this into the folder?
Well alrighty then
I think it's funny how when you type 8 and D together you get a 8D
8D 8D 8D 8D D8 8D 8D D8 8D, It worked this time. lol
1 Attachment(s)
Here is the list in PDF (easier to print and no 8D 's):-X04
Thanks |
Bump for those needing codes:-X06
Thanks for the codes, much appreciated.
2015 F250 6.7 Can anyone tell me what causes a P24B7 code? Dealer said to replace the temp sensors and i did replace all 4 of them and the mil light came back on with the same code after clearing it.
Originally Posted by Stew1022
(Post 17635607)
https://www.motorcraftservice.com/freeresources/obd |
(Post 17635607)
P247B - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 4) If you replaced the sensor and that's the only one in error, my only guess is wiring. Here's the EGT DTC list. Edit: you did say it was the same code... missed that Edit 2: per this linked post, I am incorrect. I couldn't find this code but it obviously exists for 2015+. https://www.ford-trucks.com/forums/1...l#post17635676 P0545 – Exhaust Gas Temperature Circuit Low (Sensor 1) P0546 – Exhaust Gas Temperature Sensor Circuit High (Sensor 1) P2478 – Exhaust Gas Temperature Out Of Range (Sensor 1) P2032 – Exhaust Gas Temperature Circuit Low (Sensor 2) P2033 – Exhaust Gas Temperature Sensor Circuit High (Sensor 2) P2479 – Exhaust Gas Temperature Out Of Range (Sensor 2) P242C – Exhaust Gas Temperature Circuit Low (Sensor 3) P242D – Exhaust Gas Temperature Sensor Circuit High (Sensor 3) P247A – Exhaust Gas Temperature Out Of Range (Sensor 3) P2470 – Exhaust Gas Temperature Circuit Low (Sensor 4) P2471 – Exhaust Gas Temperature Sensor Circuit High (Sensor 4) P247B – Exhaust Gas Temperature Out Of Range (Sensor 4) |
Originally Posted by kper05
(Post 17636545)
When the CEL returned, was it the same code? I'll assume you meant P247B, as B7 isn't valid.
P247B - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 4) If you replaced the sensor and that's the only one in error, my only guess is wiring. Here's the EGT DTC list. Edit: you did say it was the same code... missed that Edit 2: per this linked post, I am incorrect. I couldn't find this code but it obviously exists for 2015+. https://www.ford-trucks.com/forums/1...l#post17635676 |
I just bought the truck :)
I need help please I'm a gas mechanic and new for the diesel I bought 2011 Ford F-250 XLT crew cab 78000 mile on it tow weeks ago and I had 2 cods they keep showing up P026A & P2074 the p026a maf sensor the p2074 map sensor i clean the air filter and the maf sensor and the map sensor too and clear the codes 3 times after been everything cleaned the CEL come back after 10-20 miles drive any idea oh sorry the truck had the egr delete pdf delete and tuned.
