What do you mean 35's?
This was a response I got from the first tire place I called when trying to find someone to perform a front end alignment for me on my 250. Apparently, when I said I had 35's on it, it meant great big number 35's on the door panels, because it's a racing truck....
So the point of this post, can anyone provide-or tell me where to find- specifications(read measurements) for performing an alignment with my 35's? It has no lift, stock height, factory wheels too, just bigger tires. I have called every single shop I can find in this corner of the state, and none of them can do an alignment. Even the hillbilly shop where I live that actually installed the tires said they can't do it because they don't have spec's to go off of. Any thoughts? |
Without a lift, factory Spec's apply! Even with lift's that are designed properly, factory spec's apply. You can go more one way or another with stuff too achieve different characteristics......stock or not!
Really? Every shop had the same story, they said the foot print changes with the bigger tires so the measurements are all wrong?
I am not an alignment guy, but I would think if you didn't change the suspension at all, the tire's (even if 60") should be in the stock location's!
If you had a lift, a lot of them tell you, where to align them..........but yours is stock. On another note, other's on here ask for them to be aligned with more (camber I think) too help get rid of the twitchy steering. |
Hmmm......I wonder why all the shops won't do it then? We have to be missing something here. I wonder if they use a laser that attaches to the tire not the hub or wheel? Maybe the tires are too tall? Just speculation...I would like to get it aligned though. I didn't ask the Ford dealer because I figured they would give me the same answer, but maybe not?
Is it pulling to one side or the other? Changing the tires shoudn't knock it out of aligment. Just curious why you want an aligment, as you didn't mention any problems with it. I would take it to a Ford dealer though if you are having issues.
Originally Posted by fg250
(Post 11282168)
What kind of tires do you have? You never posted the brand and model, just that they are 35's.
Oops I'm sorry I thought I had it in my Signature I just realized I did not. They are made by a company called treadwright. Here is a link to the exact tire that I have. https://www.treadwright.com/p-79-315...dog-m-t-d.aspx
These tires are way cheaper than the toyo open country mud terrain tires or the goodyear tires that they are comparible to. Sorry if the typing is a little weird I am doing this on my phone |
Originally Posted by devongarver
(Post 11282061)
Or...might want to call Tonneau Covers, Lift Kits, Winches, Leveling Kits, Tires, Wheels & Tonneau Cover Truck Parts by 4 Wheel Parts and ask them how they would align your truck with 35" tires. If they do not know...then nobody does.:-X04 Good luck... biz :-X22 |
I've never heard such nonesense!!!! What part of USA do you live in?
The only thing that will change is the track as it will be a bit wider. It will not stop them from doing a factory alignment. Take it somewhere else.
I was looking at the specs for that tire - I guess you know that they are D rated, not E? that's another issue that they may call you on.
Don't know why they can't align it - you have stock wheels and the same tires front and back, right? The added width will be split inside/outside, so maybe you want a bit more toe to compensate for the added drag on the suspension, but caster and camber should be no problem to check and set. |
Originally Posted by Smokeispower
(Post 11475569)
Don't know why they can't align it - you have stock wheels and the same tires front and back, right? The added width will be split inside/outside, so maybe you want a bit more toe to compensate for the added drag on the suspension, but caster and camber should be no problem to check and set. And yes I do realize they are a D load rating. I actually ordered the E load rating but they called me back and said they did not have it available |
I do not understand why they are giving me such a hard time I will go elsewhere right now it is not as much of a concern because I drive a company vehicle daily.
