2011-12 DynoMax VT exhaust system for the Ford F-150
We are excited to launch our VT system for the 2011-12 F-150.
The VT muffler allows for a straight through exhaust when on the throttle but when you are cruising or idling the exhaust isn't over the top. 90 day Performance and Sound Guarantee as well. If you aren't completely satisfied, return it for a refund. You should,hopefully, also see gains in both HP and TQ with this system as it is not as restrictive as the stock muffler. http://i1198.photobucket.com/albums/...0_VT_38514.jpg |
Hi,
Which model # muffler do you recommend for the 5.0 F150? |
Originally Posted by jmallash
(Post 11311537)
Hi,
Which model # muffler do you recommend for the 5.0 F150? Dynomax® Performance Exhaust | Mufflers | Ultra Flo™ Welded Mufflers |
What size do you recommend for the ultra flo? I know 3" in 3" out. To just do a muffler swap should I get the center in center out?
I'm actually interested in the Dynomax Vt. Drone free. Will the model #17962 fit the 2011 F150 5.0? Thanks, Jerry |
(Post 11329355)
I'm actually interested in the Dynomax Vt. Drone free. Will the model #17962 fit the 2011 F150 5.0? Thanks, Jerry This is the correct P/N as long as same in/out as stock. Sorry so long on a response too, I need to change my settings to "instant". |
Actually, stock is 2 3/4" off center in, 3" off center out on the same side. is there a dynomax VT muffler with that configuration?
(Post 11337696)
They don't make it easy do they? We don't make one in that configuration, that is why we made this system. Sorry about that. |
