Dying Starter Solenoid?
Before I order a new one, just want to double check with you guys. When it's cold (30deg or lower) my starter doesn't always catch the flywheel. It will spin, or just click and I need to tap on the solenoid to get it to work. New batteries and new alternator 3 months ago.
How much is a solenoid? I have a 2 bolt OSGR starter |
I'm having trouble finding a part # for the starter solenoid...I hope I don't have to get a whole new starter. Mine cranks like a ******* when it works!
You are talking about the solenoid on the starter not the relay on the inner fender ? Did you check and make sure the starter bolts were tight ? I would also check your ground wires . I don't know if they make a seperate solenoid for are starters but I have usually found that when you have to tap on the starter to get it to spin its starter time.
if its the 03 in the signature, I do not think they have the fender mounted solenoid on them. I would take it off and get it gone through at the rebuild shop if the mounting bolts are tight.
Originally Posted by 1996pwrstrk
(Post 11236766)
I turn the keep and get the WTS light First try starting, the starter will spin and not engage the motor Second try it will just click as if the batteries are too low Tap the starter/solenoid Starts up fine The starter was slightly loose a while ago but I've since tightened it up. Out of curiosity though how would this affect it not activating when the key is turned? The connections should all be tight. Last winter I had a problem with it spinning and not engaging the motor. |
Originally Posted by carltonwebb
(Post 11236811)
Originally Posted by Rose Clifford
(Post 11236821)
The starter was slightly loose a while ago but I've since tightened it up. Out of curiosity though how would this affect it not activating when the key is turned? . |
You are right. It sounds like the solenoid, a burr on the bendix drive, or possibly a bad spot on the armature by what you are describing or possible a little of all 3.
You probably know about this place but just in case. I ordered one for my 2000 from here and it works great> They may have the solenoid for u as well. http://www.db-starter-alternator.com/ |
carltonwebb thank you for that info I thought they all had the relay on the inner fender.
(Post 11236884)
I learned it here from someone else. I think 2002 is the 1st year without it. My 2000 and 2001 both have it. |
Ford started using a "2 bolt" OSGR starter on 2/27/01, before then they were "3 bolt" starters.
I'll try snugging everything up tonight....why would it only happen in the cold though? |
most starters weak point is the solinoid or the pinnion drive , yours could be the solinoid , but it could be just really sticky or rust and dry where the pinnion slides on the armature shaft,I use to rebuild starters for a hobby
Originally Posted by crop harvester
(Post 11238502)
when mine went out, i was told that you couldnt buy just the solinoid..had to buy a complete starter
just replaced the starter (and alternator) yesterday. damn, what a difference.
if you are going through the trouble, just replace the entire thing. it's a PITA. |
