Ford Truck Enthusiasts Forums
-   Mississippi Chapter (https://www.ford-trucks.com/forums/forum215/)
-   -   56 F100 build photos (https://www.ford-trucks.com/forums/1123736-56-f100-build-photos.html)
3golfjack 12-18-2011 08:05 AM
Well I finally found me some seats for my 56. These are a set of black leather seats out of a 2003 Jeep Grand Cherokee. Need to find some seat belts now.https://www.ford-trucks.com/forums/p...ictureid=87702https://www.ford-trucks.com/forums/p...ictureid=87703https://www.ford-trucks.com/forums/p...ictureid=87704[/IMG][/IMG]
gatormccluskey 12-18-2011 08:28 AM
Looking good. I like the color and the seats. :-jammin It will look good at Crusin the Coast
Layed Out 100 12-20-2011 12:00 PM
Those seats look great, I would be sitting behind the wheel acting like I was driving if mine had a seat!
3golfjack 12-20-2011 05:19 PM
I would almost say you been watching me. I'm leaning on cutting a couple of inches above the steering column to allow it to tilt just a little more. I have the linkage to tie into the racket pinion ( three u-joints, bearing hanger & 3/4" bar ) but I waited for a seat to see how it fitted first, just in case I wanted to move it around some. Been working to much to get anything done.
Layed Out 100 12-21-2011 10:21 AM
LOL, what size column did you use? I wanted to put one on my christmas list this year but didn't figure out the length in time.
3golfjack 12-21-2011 05:10 PM
I went with a 32" column but I wish I would had went shorter maybe 30 or 31. I think this would had give me more room around the plug wires. You can see the line above the column where I'm thinking about cutting out some to help get more tilt at the steering wheel end.
https://www.ford-trucks.com/forums/p...ictureid=87978
3golfjack 12-22-2011 10:29 AM
More build photos.
https://www.ford-trucks.com/forums/p...ictureid=74619https://www.ford-trucks.com/forums/p...ictureid=74620
https://www.ford-trucks.com/forums/p...ictureid=74618
https://www.ford-trucks.com/forums/p...ictureid=60257
https://www.ford-trucks.com/forums/p...ictureid=60256
https://www.ford-trucks.com/forums/p...ictureid=60255
https://www.ford-trucks.com/forums/p...ictureid=60251
https://www.ford-trucks.com/forums/p...ictureid=85016
3golfjack 12-31-2011 05:01 PM
Been working on the rear lower corners.Just about done with the right side.
Replaced the inner and outer corner.
This is the right inner section.
https://www.ford-trucks.com/forums/p...ictureid=54588
This is the outer section.
https://www.ford-trucks.com/forums/p...ictureid=88840
This is the cut away on the drivers side. This side will need the inner and outer plus the rocker panel and the lower section of the door post replaced.
https://www.ford-trucks.com/forums/p...ictureid=88841
https://www.ford-trucks.com/forums/p...ictureid=88842
As you can see there is a lot of rust still to cut out.
Layed Out 100 12-31-2011 09:51 PM
Good looking work on your cab corners.....ill be doing mine soon also. I have the new outside pieces but didn't order the inside yet. Don't really know if I need them until I do some cutting.
Layed Out 100 01-31-2012 12:09 AM
I dont know why I didn't nottice before but your fire wall looks good! did you weld all the holes up or replace the whole thing?
3golfjack 01-31-2012 05:37 PM
Adam,
I replace the firewall. It came as two pieces. I wish I could had found a nice low rust cab around this area but I didn't have any luck. On the cab I've had to replace the firewall,front floor pans, rear inner and outer corners,both rear lower door jams and one rocker arm.
Layed Out 100 01-31-2012 09:24 PM
Yea, I went back and looked through your gallery after I posted. Man you have done a lot of good looking work to it.
3golfjack 03-11-2012 08:57 AM
Finished my steering linkage. Went with all stainless.
https://www.ford-trucks.com/forums/p...ictureid=95144
https://www.ford-trucks.com/forums/p...ictureid=95143
3golfjack 03-11-2012 09:38 AM
Build Spec
1956 F100 purchased 2007
motor- 302 1978 F100 rebuilt with 25000 miles on it.
Oil pan- rear sump
carburetor- Holley 4 barrel 600 CFM
carb linkage- Lokar DP-1000HT
transmission- C6 78 F100 Rebuilt 10,000 miles on it.
Trans kick-down- Lokar KD-20C6HT
Steering- Rack&Pinion
Front end- MII Heidt's
Rear end- 8.8 3.55 91 Ford Explorer
Rear leaf springs- Speedway motors with 3" drop
Front Brakes- Disc front A1 Cardone 11" rotors
Rear brakes- Drum stock
front wheels- 15x7 3.75 backspacing Crager SS
front tire- 225x75 R15 Firestone
rear wheel- 15x8 4.5 backspacing Crager SS
rear tire- 255x70 R15 Firestone
Wiring- EZ wiring
Gauges- Dolphin
Headers- BBK ceramic coated
Exhaust- 2 1/2" mustang h-pipe, magnaflow mufflers
Layed Out 100 03-12-2012 12:06 AM
Wow!!! that looks really good.
You sneaky sneaky! lol I thought we were working too much to work on our trucks.... now I got to go work on mine.
