How-To install cab lights
16 Attachment(s)
This topic comes up pretty often so I figured I would do How to since I was installing them on my 97. This is not for the faint of heart. You have to drill 15 holes
The harness is the same from the 70s-97, with the only differences being on the end where it plugs into the truck. I had a 89 harness so I had to change the plug at the end. NOT a big deal. The 70s-91 have one type of plug, the 92-97 have another. 92-97 have the power lug on the passenger side. 80-91 have the power plug on the drivers side. Adjust accordingly First I will show you what the FACTORY cab holes looks like. The hole is big enough to put the entire socket thru it. and Ford uses the little speed clips for the attaching screws(not necessary) Attachment 234187 Ok. 1st Tape off the general are where each light will go. The light is set back from the windshield trim 3 3/8" and they are evenly spaced out at 12". Find the center of the roof and work your way out. Remember measure TWICE if need be. Then lay the lights on the roof and and back and look at them to make sure they look right. Do fine tuning as you see fit. I like to have them as close to factory as possible, all facing straight ahead. Some like to have them follow the arc of the roof. Attachment 234188 Attachment 234189 Once you get them where your want them, mark your screw holes. Then remove the light and mark a spot of the wire to pass thru about dead center between the screw holes Then get out your drill and drill away. Just drill thru the OUTER roof. DO NOT drill thru the inner roof. I use a 7/64" bit to drill all the holes. Then I come back with a UNI-BIT and open up the WIRE holes to 3/4". Attachment 234190 Attachment 234191 Next up is fishing the wire thru the roof. Remove the passenger side sun visor. You will need to use the visor hole to fish the wire. The best way I have found to fish the wire is like so. Take a coat hanger and straighten it out and bend a SMALL loop on the end. The tire a good piece of string thru the loop. Attachment 234192 Start on the drivers side and fish it in the 1st hole and try to get it out the middle hole. Once you get it out the middle hole pull the coat hanger completely out. then stick it back in the middle hole and try to get it out the far passenger side hole. Again, pull the coat hanger all the way out then stick it back in the far passenger side hole and thru the inside hole for the passenger visor.Attachment 234193 Pull the coat hanger all the way out and untie the string. Tie the string onto the harness for the drivers side light(unplug all the 5 light sockets from the harness). If you left your self enough string you can have it come thru the drivers door and to the passenger side with the string. This will allow you to pull the string and feed the harness at the same time Attachment 234194 Keep feeding the harness and pulling the string. Once the last cab light plug goes into the visor hole, the 1st cab light pug should hit a stopping point. Then you need to get a pair of needle nose pliers to pull each connector from each hole Attachment 234195 Now you need to fish the passenger side A pillar. Remove the Kick panel and A pillar cover.Again with the coat hanger and string. Start at the top in the visor hole and work the coat hanger down the A pillar. Once it is thru tie the other end of the string to the plug on the other end of the harness w a stopper knot and tape the dead so it will not get caught while pulling Attachment 234196 it is a tight fit so just keep pulling and feeding at the same time. Once you get the head down to the kick panel you will need to plug it into the truck side harness. This plug Attachment 234197 I had to modify my harness to fit the plug(because I had an older harness). Plug in the 5 sockets for the cab lights and turn on your headlights. You SHOULD have lights. Putting the cab lights on is pretty simple. The sockets are a 1/4 turn in to the lens and I use #8 stainless pan head screws a Neoprene washers to seal better. I also put silicone on the treads of each screw as well Attachment 234198 Tighten the screws but DO NOT OVER TIGHTEN There is no need for silicone on the cab light gasket, that will just make thing harder if.when a cab light burns out. And there ya go. Cab lights 101 Attachment 234199 Attachment 234200 Attachment 234201 Attachment 234202 |
Looks good, thanks for the write up. It is asked often and I know someday i plan on doing this. Just hard to find good ones in the j/y.
Not sure why you'd *want* potentially leaky, scraped up junkyard cab lights considering you can buy a set of five for about $30-35 brand new.
Nice write up Brad, and you're right, the most difficult part of this kind of project is drilling the first hole through the roof. |
thanks brad I plan on doing this in the spring
Fredric, I dont know where you are getting new lights for 30-35 but I want some. And I'm not talking abot those POS LMC one that dont even use a CORRECT socket
Excellent write up!!!!
Damn thing won't let me rep ya! |
Actually, I just fond them for $4.88 a piece! Think I'm gonna order me up some NEW shiny lens'
Originally Posted by Diesel_Brad
(Post 11149997)
http://frederic.woodbridgedata.com/p...console-13.JPG
(Post 11150059)
I drilled for mine a little differently - since the socket is in the housing itself, I only had to drill a 1/4: diameter hole for the plastic hollow post to stick through. The post sticks through the roof sheet metal so the wire going through the center doesn't get cut on the drilled hole. I drilled that one first, put the light on so the hollow post went through, adjusted it to a straight position, then drilled the mounting screw holes slightly undersized to the screws. I had originally replaced the outer two sockets with two-wire sockets and installed dual-filiment bulbs so they'd light up with the others but also act as turn signals. That got annoying at night reflecting on the hood so I installed the original sockets back in and wired accordingly. I use a switch in the Chrysler overhead console I installed to operate them separately from the parking lights and the center console taps power from the mounting flange of the original, mostly useless interior light that the console covers. http://frederic.woodbridgedata.com/p...console-12.JPG |
(Post 11150059)
hey brad i got a ? what year truck is that cause my roof top is smooth not ribbed like that one just curious.
Originally Posted by F350Kid238
(Post 11167936)
Its either a extended or CC truck, roof is longer so its ribbed for added support. Regular cab roof doesn't need em, "acreage" up there isn't as great. |
ohh that makes sense thanks for the answer dan
Originally Posted by danr1
(Post 11167952)
While I'm not Brad think I can answer that for ya.
Thanks for the link Brad, going to order them soon.
