6.7 Glow Plug dropped ( pic added )
I would like to know if i am the only one that had that problem... a few weeks ago, I had to stop and get the truck towed to the dealership and they told me that my engine was shot :-arrgh
Then they told me it was a glow plug that fell inside the cylinder... didn't know it was possible :-huh but any way it was under warranty. Last Monday they asked me to bring all my service receipt and that ford is asking them to take the engine apart and study it before they would ship a new engine... Are the trying to get away from paying it under warranty ? The truck is 2011 with 80000 km ( 50000 miles ). Anybody went through that before ? |
I have heard of this before
I have seen/heard it on the 6.0 Rare and 7.3 and 6.4.
I have not seen it on the 6.7. I hope it is good news that MAYBE they will try to fix this problem in the next production run. Is your truck stock? Donovan |
2.5 leveling kit at the front and 35x12.5 tires...
The problem is i bought the truck at 35,000 miles (60000 km) and i have no idea what has been done prior to that as maintenance goes... |
Originally Posted by 04xcur
(Post 11121215)
The problem is i bought the truck at 35,000 miles (60000 km) and i have no idea what has been done prior to that as maintenance goes... I would be interested in hearing how they think service records relate to a glow plug breaking off. :confused: As far as service records before you bought it, that is tough. Dealers are forbidden by law from giving you any records from a previous owner (privacy concerns). If you bought it from a Ford dealer, they should have documented the condition of the vehicle before they sold it to you. That would be your best case scenario. Worst case would be if you bought it private party with no service records. I would try running a Carfax report to try and fill in any gaps in service records. Just in case it becomes an issue. Also, register with the Ford owner web site, and then check for service that might have been performed by a Ford dealership. |
One indication that this is a rare problem, Ford wants to study the engine.
Moved to the 6.7L Power Stroke Diesel forum.
I've read of a couple or so incidents of this happening to the 6.7. Somewhere I've also read that this can be caused by failing to wait for the glow plug light to go off before cranking but I don't know if there is any basis for that claim.
Is this a cab and chassis?
I've not heard of this issue at all with the 6.7L that I remember but I'll be more shocked if this is the pickup 6.7L instead of the C&C 6.7L. The C&C engines have had a few more issues. |
Originally Posted by Glockin' Bob
(Post 11122817)
I'm not sure how not waiting for the light to go out could cause this, even after the light goes out that isn't the end of the glowplug cycle. |
The truck is a F350 CC FX4 Lariat.
There is one thing i noticed is when i use the remote start (witch i use a lot living an hour away from Alaska !) the truck doesn't look like it wait for the glow plug to turn off before it starts the truck... maybe there is something there... |
If the truck was serviced at a Ford Dealer, The records will be in the Oasis computer report. So it is only records of service NOT at a Ford deaker that they will really be looking at.
I'm sure they will look for any work that would have removed and replace a glow plug where they can put the blame on improper replacement. |
Originally Posted by rollerstud98
(Post 11123288)
I wish Ford would do like Cummins and eliminate glowplugs in favor of the intake grid, it seems to be more reliable and there can be no plugs falling into cylinders destroying engines. |
Someone can correct me, but I remember reading somewhere that the glow plug remains energized even after engine start and remains on for some period of time. I don't think that whether the truck starts with the plug hot or not has anything to do with this failure. I'm also interested to know if this failure was on a cab and chassis model.
Originally Posted by EpicCowlick
(Post 11124270)
This seems like a defect, plain and simple. A relatively catastrophic one at that, but you shouldnt have any trouble getting this covered under warranty. Please let us know how it goes! |
(Post 11123389)
(Post 11124270)
The main factors that determine the wait to start light post time and how long the glow plugs will remain active after the engine is running are the coolant temperature and battery voltage... |
