460/Aod Is This Possible?
I have a 78 f150 4x4 with 351m/c6. I'm wanting to put in a 460. The question is that I'm thinking about putting an Aod trans in it. Is there anyway to do this or do I have to stick with the c6.
They had those two together in the 90's 250's/350's I know of at the least, so I don't see why not. Someone else might be able to tell you otherwise.
Apparently yes: Ford 429/460 to AOD
For what that adapter costs, you can buy a controller for an E4OD, which is a MUCH better transmission. It won't play nicely with the 205 thats in that F150 though.
Originally Posted by LARIAT 85
(Post 11105542)
In stock form, the AOD was never offered behind anything larger than a 5.0/302 from Ford. The only exception was the police cars that were outfitted in the early 1980s with a 351 H.O. with an AOD transmission.
Performance Automatic offers an AOD to 460 conversion kit but it ain't cheap....starts at $3,971:
Performance Automatic - AOD Ford Transmission Performance Automatic - AOD Ford Street Smart System |
An AOD wasn't offered behind a 351, much less a 460, and certainly not an F350. The AOD was considered a light duty transmission. However, they can be beefed up to work behind the bigger engines.
The AOD was dropped after 1993. Your friend's F350 must have had a 4R70W, which is a revised, computer-controlled automatic overdrive transmission. The earlier AOD has no computer to run it and is completely mechanical, making it a popular swap on older vehicles. |
(Post 11110701)
(Post 11105542)
In stock form, the AOD was never offered behind anything larger than a 5.0/302 from Ford. :-huh
The only exception was the police cars that were outfitted in the early 1980s with a 351 H.O. with an AOD transmission. Didn't look after 1989. |
Thank you for the correction, NumberDummy. I don't need to be giving out false information either! :-X22
I had a '90 F250 2WD SC w/460 and auto transmission. It came with factory overdrive with a switch on the dash to activate it, when desired, but I couldn't tell you they model or type of transmission but I'm sure Bill would know.
I too would like to have something like that in my '74 F350 w/460 but based upon my research, it would be very expensive and probably cost prohibitive. :( |
The AOD never had the switch on the dash to de-activate the overdrive gear; that would have been one of the newer computer-controlled automatic overdrive transmissions.
The overdrive on the AOD could only be de-activated by the gear selector on the column. The column on the AOD would have been set up like this: P R N OD D 1. The OD would be the overdrive gear of course, and the D would be the overdrive lockout position. The earliest models would have had P R N OD 3 1. |
(Post 11113035)
E4OD / The O/D switch could be on the dash, but it's also on the end of the shift lever (depends on apps), is notorious for snapping off. At least once a wwek, someone is b!tchin' about the little charmer. The overdrive on the AOD could only be de-activated by the gear selector on the column. The column on the AOD would have been set up like this: P R N OD :-huh D 1. The OD would be the overdrive gear of course, and the D would be the overdrive lockout position. The earliest models would have had P R N OD 3 1. O typed in red for emphasis purposes only. |
Its: P R N O D 2 1 / Never seen a AOD (Ford: AOT) quadrant with OD. :-huh
