exploded view of front axle
I need to replace the pass side front axle shaft on my 96 F-250. This is the one where it destroyed the yoke on the wheel side. Does anyone have an exploded view of the axle? I am thinking I should be able to pull most of it apart in large sections. I am thinking pulling calliper, then dropping at ball joints and the knuckle should come out as a unit. I am not sure if I have to open up the hub assembly or not to release any retaining clips in there or if it is designed to slide in and out freely. If I took it out this way could I do this enough to seperate from the truck and have the shaft and hub assembly seperated and work at it on a bench? Would that be easier that piece by piece on the vehicle?
Also the inner side which I would have assumed, went to another univeral then to the diff, has a set of splines on it, and i am not seeing a carrier bearing where they are telling me it should snap into. Since it snapped the yoke at the wheel I am contemplating only replacing that portion and leaving the other sections alone. Thoughts? |
Is it a Dana 44, 50, or 60?
It'll give you one here, you can not remove the knuckle without pulling the axle first.
http://www.google.com/url?sa=t&rct=j...6z8V-vo7oRZXtw Remove caliper, lockout, hub and then spindle then axle slides out through knuckle. Passenger side axle separates at slip joint outboard of inner stub shaft at pig. Undo boot clamp so as axle will slide out of slip joint and out clear of knuckle. |
You don't need to remove the knuckle to replace the shaft.
The passenger side axle is two pieces. There is a slip joint in the middle covered by a rubber boot. You have to remove the clips holding one side of the boot in place. Then remove the rotor and spindle and the axle will slide out. The inner piece of the shaft stays in the differential (it's clipped) and you don't need to mess with it. |
Thank you for the responses on this. It is a dana 50
I am thinking I am probably better off replacing the broken unit with the replacement unit vs just the portion that snapped wheel side. This way I can replace the U- joint on the on that is ready to go back in and have it all set slide in out and done/ vs replacing the u- joint in there. Any Idea roughly how long this takes? I am thinking prob 4-5 hrs? Depending how cooperative each piece is in comingoff. |
Originally Posted by vasten
(Post 11070387)
I am thinking I am probably better off replacing the broken unit with the replacement unit vs just the portion that snapped wheel side. This way I can replace the U- joint on the on that is ready to go back in and have it all set slide in out and done/ vs replacing the u- joint in there. Any Idea roughly how long this takes? I am thinking prob 4-5 hrs? Depending how cooperative each piece is in comingoff. Replacing the u-joint is not that hard and won't take long. Most of the labor is going to be getting it apart and back together. You won't save yourself that much time by using a replacement part. It will cost you a bunch extra to buy the replacement part though. |
So is the u-joint broke or the outer axle stub?
If the outer axle stup is F-d up, just go get a used one from a Junk yard for about $25 and put a GOOD u-joint in for another $30 |
kind of the chicken or the egg... the outter axle stub yoke snapped, and the u joint. So not sure if the u joint seized up and snapped and took out the yoke or the other way around.
The only part I could find at a junk yard is the axle shaft that goes from the hub to the slip joint. I was planning on replacing the Universal in that then sliding it all back in as a unit. wish I could have found one for 25.00 when I was searching the only parts I could find was the entire shaft and cheapest one I found was 90.00 the others were over 200.00 |
I removed my spindle from my 96F250 with dana 50 by beating it sideways with a rubber mallet. Hit it each direction and it will loosen up. No tool rental required. No rust up here in Fairbanks though.
(Post 11071306)
Originally Posted by jimbo285
(Post 11073573)
Found this manual at the Dana web site today: http://www2.dana.com/pdf/5326.pdf
Better late than never......... |
Rubber mallet. Less noise.
Originally Posted by rla2005
(Post 11089157)
Make sure the u-joints on the axle line up the same with the one coming out of the diff. Bad things can happen if they don't.
