61 Signal cam issues
I have a 61 unibody and I am using the original three on the tree column. I am having real issues finding all of the "guts". For the signal and horn assembly located under the steering wheel. Does anyone have a diagram? Will the parts from a Falcon work?
The plate assembly is metal. Only the switch needs to be replaced if bad. Dennis Carpenter lists the switch for $40.00 PN C0DZ-13341-A I know of no one who carries the complete unit.
If you need the entire unit you will have to scrounge one out of a F100 F250 61 or 62 Garbz |
Originally Posted by 64blue
(Post 11055768)
I have a 61 unibody and I am using the original three on the tree column. I am having real issues finding all of the "guts."
For the signal and horn assembly located under the steering wheel. Will the parts from a Falcon work? CODF-13304-A .. T/S Switch Mounting Plate / Obsolete WESLEY OBSOLETE PARTS in Liberty KY has 4 = 606-787-5293. GREEN SALES CO. in Cincinnati OH has 8 = 800-543-4959. ------------------------------------------------------- CODZ-13341-A .. T/S Switch-less mounting plate / Obsolete WESLEY OBSOLETE PARTS has 10. GREEN SALES CO. has 11. CARPENTER NOS OBSOLETE PARTS in Concord NC has 116 = 800-476-9653. What horn parts are you asking for? Does your truck have a horn ring ot horn button? |
