Project: Smogie...RacinNdrummins IDI build
85 Attachment(s)
So anyway, I have been keeping this thread going over on PSN (And OBN before that),and I have been working on this for the last 6 months or so.
Ive been a ranger guy for a while, I love the trucks, had several of them over the years, and Ive owned a couple B2's as well. I also race motocross (The Racin in RacinNdrummin) and I have getten tired of bumming a place to sleep while im out at the track (Two days races, etc). This brought on the decision to buy a travel trailer so I could have my own place to sleep and hang out while im at the track, also I wanted to go camping in comfort when Im not out at the track. This posed a little bit of a problem, rangers dont like to tow 25+ ft travel trailers. A couple years ago I had bought an 89 F250 for $500 that had a 351w with a "bad" transmission... Well first thing I did was peek underneath and I saw it was a C6 trans... Sold. 5 minutes and a pair of scissors later, I was driving a truck that shifted fine... Broken Vacuum line to the modulator... So after several months of driving that thing around (Just for the hell of it, it was in good shape) I got really sick of getting 10mpg... Best I ever got was 11mpg Hwy... So needless to say that wasnt going to work. After a couple of months of sitting, I sold the truck to my dad, and then it sat at his house (His F4TE 351 swapped F150 would out tow this F250)... Fast forward to earlier this year... After I decided to buy a truck to tow a trailer, I wanted something that I could burn WVO and WMO in without causing too many problems (Free fuel bro!), and I bleed ford blue, so that narrowed me down to one option... The IDI. I started looking around at IDI trucks (knowing nothing about them) and the first truck that interested me was a 94 Turbo F250 SC 4x4 that was pretty "clapped out" at a dealership. 200K and missing half the dash, but still an IDI and the last year of them... I figured I could buy it and fix it up. Problem was that the dealership wanted 6k for it and My budget was right around the $4500 mark. I told them how clapped out the truck was, and that Id buy it for $3500 out the door, no questions asked... And while im sure they would have taken that in a heartbeat (They had the truck inspected, and failed horribly) the owner didnt want to sell because of some sort of "5 star" dealership BS... he wanted to put money into it and sell it in a decent shape for 6K.........= Boned. So After all That, I decided I still wanted an IDIT, and after a couple of leads, I came up empty handed. Until one day while browsing CL, I came across a guy parting a 94IDIT/ZF5 with 160k on the clock, went and test drove the truck, and decided that was the powerplant I wanted. So I dropped $1750 for the Engine/Trans and all the rest of the swap stuff I needed. I then proceded to buy the old F250 back off my Dad, and he ended up just giving it to me after I told him the plan...So here goes.. Attachment 233706 Attachment 233707 Attachment 233708 Attachment 233709 Attachment 233710 Attachment 233711 I decided to swap the IDIT/ZF5 into the F250 and have a truck that would do everything I wanted, was paid for, and old enough to not have to worry about much. The plan was to run it stock (It already had a rebuilt IP and injectors). Toss it in and go... Well about that time 1badb2(NMB2) had moved up my way and after sharing several interests, we became friends. I got to drive his "Imfamous" Flatbed and after that I couldnt bring myself to put my engine in my truck stock. I had an HY35 turbo on my shelf from a previous project, and I thought, "why not", so I made it fit the stock ATS setup... Attachment 233712 Attachment 233713 Attachment 233713 Attachment 233715 Attachment 233716 Attachment 233717 After some research, I decided that the HY was going to be a bit small for my needs, and while looking for an HX35 to replace it with, I came across a CL ad for a "Turbo" for $100... Turbo was brand new and Turned out to be a Borg-Warner S362/74/14 off of a CAT C7... Needless to say, I bought the Turbo ($1800 turbo for $100, Id say so, and he had 2, 1badb2 bought the other) Attachment 233718 Attachment 233719 Attachment 233720 Attachment 233721 Attachment 233722 Attachment 233723 I was going to run the turbo on the stock ATS setup when I came to my senses and decided that I needed to do a custom setup. I figured, if I was going to do a custom setup, then I needed to stud it (Any IDI running any boost, should be studded, bar none). So apart came the engine... Attachment 233724 Attachment 233725 Attachment 233726 Attachment 233727 Attachment 233728 Cleaned everything up and installed comp 910 springs in the heads: Attachment 233729 Installed the heads, ARP studs torqued to 150ft/lbs (Yes, you read that right) on Felpro head gaskets... Attachment 233730 Attachment 233731 After discussing cam options for the 7.3 with the guys at delta, we came up with an option slightly bigger than the "TYP4" cam meant more for a higher boost turbocharged application... This cam is referred to as the J2 "powershaft"... Both 1badb2 and I are the first to run this cam, and it is probably the best cam for a boosted IDI you can get, it is very efficient... Attachment 233732 Attachment 233733 Got the engine all assembled, and painted... Attachment 233734 Attachment 233735 Attachment 233736 Attachment 233737 Attachment 233738 Hydroboost and MANpedal installed: Attachment 233739 Attachment 233740 I also did what everybody said couldnt be done... I installed 92+ quarter windows in a 91- truck... The hole is a bit smaller, but can be made to work.... Attachment 233741 Attachment 233742 Then I had 3/8" flanges waterjetted... Attachment 233743 1badb2's old DPS Turbo cal pump from his flatbed Attachment 233744 Then I decided I was going to cut up my intake manifold and "improve" it... Took out the pinch points, cut it in half, made positive connections, etc.... Attachment 233745 Attachment 233746 Attachment 233747 Attachment 233748 Attachment 233749 Attachment 233750 Attachment 233751 Attachment 233752 Attachment 233753 Attachment 233754 Bought a parts truck for the diesel title and VIN, as well as the cab (had some features I wanted) and Diesel specific stuff... Ended up breaking even after collecting the parts I wanted and selling the rest off... Attachment 233755 Attachment 233756 Attachment 233757 Attachment 233758 Attachment 233759 Attachment 233760 Proceded to tear the parts truck apart... Attachment 233761 Attachment 233762 Attachment 233763 Took the Brown truck down to the frame and cleaned it up, swapped over the frame harness and tank units... Attachment 233764 Attachment 233765 Attachment 233766 Attachment 233767 Installed engine and Trans... Attachment 233768 Cab, bed, frontend... Attachment 233769 Attachment 233770 Junkyard interior, With a LMC truck/ACC vinyl floor that never did fit, and is the biggest heap of crap, replaced with a factory carpet, that is soon to be repaced with a factory vinyl floor, that will probably be replaced with a new carpet... Attachment 233771 Attachment 233772 Started my turbo kit... Attachment 233773 Attachment 233774 Attachment 233775 Intake studs, and intake installed... Attachment 233776 Attachment 233777 IP and misc... Attachment 233778 Attachment 233779 Attachment 233780 Attachment 233781 Interior installed... Attachment 233782 Attachment 233783 Attachment 233784 mani's... Attachment 233785 Attachment 233786 Kit installed... Attachment 233787 Almost done... Attachment 233788 Attachment 233789 Attachment 233790 And the first fire up... M4H00446.MP4 - YouTube I messed up and said S366... I Meant S362.. Ive driven it since and I will update this thread with more info as I go! |
Holy crap...
Can't wait to ride in it! Congrats again bro
Nice build man, very nice. On that cam do you know the LSA, cam advance, or even the cam timing events? Also did you have to use different push rods to compensate for material removed from the base circle? Thanks.
seeing yours and nmbs trucks done is making me impatient haha. Ive got my 7.3 torn down and im waiting for my cam from delta and injectors, which are hopefully coming this week
Originally Posted by SnuffthePunkz
(Post 11034525)
Holy crap...
Nice work! |
lmk how side mounted works as we all know i been building that style for over a year now and still havnt had time to finish yet.
Good god....... how much money do you have tied up in that thing? that is bad man bad..... i want it. :-X06
Awesom..... nice work man
Between you and 1badb2, you guys have done an amazing job in your builds! A big THANK YOU goes out to you both for the great documentation and info!
I....wanna do this too.....
I have about 6K total into the whole project, $4500 cash to start and the last $1500 Ive put in out of my own pocket and by selling stuff. Still beats spending 21k on a ranger you cant do anything with (Ask me how I know)
Im working on getting some specs of the cam, I dont have them right in front of me, but it is basically a more exhaust biased version of the Typ4 cam, and that is why it has such good spool characteristics. I did nothing to the valvetrain, except for installing comp 910 springs... Stock Pushrods, Lifters, Rockers... Only thing different was the springs. The valve lash was right at its limit though, I only have a quarter turn of lash on all my lifters... Anyway, thanks for the compliments... |
WOW 6K?! I was thinkin that just a base rebuild on a 7.3 would run me close to 5k but I think I can do better now.
I'm doing turn-key engines like mine. PM me if interested. I already have one I'm about to start for a customer out in jersey.
Where you based out of? I also love the 92-96 ext-cab interior did you need to modify anythin to fit the older cab?
