Truck will not start or crank.
My father-in-law's truck won't start so he asked me if I could diagnose the problem. The truck is a '02 F250 supercab 4x4 with the V10(41K miles) and 4R100 transmission. He only uses his truck about 10 times a year so needless to say, it does a lot of sitting. He jumped in it the other day and all the lights and chimes turned on but when he turned the key forward it did nothing. I told him to check his connections and try a new battery if the connections were fine so he did. Still nothing. I made the 2 hour trip to his house to see if I could help but I don't have much experience with Super Dutys and no experience with the Ford V10. I can dismantle any OBS Ford with my eyes closed and put it back together just the same so I have a lot of experience with trucks just not his so I was wondering if there were any tricks with these trucks I'm not aware of.
So far what we have checked/done is: First, I told him to make sure the truck was fully in Park or Neutral before he tried starting but it was fully engaged. Then he put in a new battery and when that wouldn't work I had to come check it out. I disconnected all wires that connect to the battery and cleaned the contacts. The same goes for the starter. We found the chassis to body ground had rotted off so we made up a new ground because I have experienced that as the cause of a truck not starting in the past. Still nothing. No clicking, no cranking, nothing but the lights and chimes come on. My next guess is to tell him to have the starter checked at Autozone or somewhere. I noticed there isn't a fender mounted starter solenoid on these trucks so is the one on the starter itself it? My next guess is the starter relay, what do you guys think? |
Are you getting any fire to the starter solenoid ?
..I would reccomend taking off serpentine belt and spin all accessories...if the air condiotioning compressor is seized it will not allow motor to turn over..if that is the case you can take compressor off..and replace with a "dummy pulley" on it's own perch so you continue to use same size serpentine belt..I had the same scenario on my 01 SD F250 5.4 2 years ago..good luck..George
Originally Posted by gatormccluskey
(Post 10926778)
Check for current draw. Turn lights on. Try to start engine. Do headlights dim?
If so, you're getting current to the starter. Either the battery doesn't have enough power to turn engine over, wiring (current path) is bad, starter is locked or engine is locked. If lights do not dim, you're not getting current to (and through) the starter. Look a solenoid, wiring, park/neutral switch. |
Originally Posted by redford
(Post 10927049)
Nothing special with fords... Key sw to start relay to solenoid on fender wall..At least on my year..Work backwards apply 12v to starter small wire. Truck should turn over with key off. If does go back to solenoid on fender wall apply 12v to small wire truck should turn over..
You already know to check P N sw..At least if you work backwards you can eliminate some things...12v relay in under hood relay panel I think.. Pull out and push in.. Dick |
What is the chances the starter hung out due to low voltage? He may find when he pulls it off thats the case and it will crank.
Guy's he isn't hearing anything no solenoids thumping nothing..Which means the solenoids /relays are not even getting voltage...
Dick |
I'd be looking for grounds speciffically the incoming chassis ground on the block, the ground strap between engine & chassis at the firewall as well as the positive battery cable chassis accy power tap connection usually a 10mm nut and very susceptible to corrosion!
Jim & fat Monty}> |
Originally Posted by hotroddsl
(Post 10928724)
Jim & fat Monty}> |
