FICM repaired, but issue
ALrighty, I finally received my repaired FICM unit and worked at putting it in the truck. I ran into an issue. The middle plug that goes into the FICM I believe is missing some kind of clip that makes it "snap" in there. So no matter how hard I pushed, it would not lock in there. I put it in there went ahead and tightened the FICM, and the truck runs great. The plug stayed in pretty good, but I took a small 100 mile journey. During this journey, the plug came out and the truck started running very rough and shaking badly. I stopped at the nearest exit and touched the second plug and the truck went back to running fine. Any fixes? Can I get this plug replaced at the Ford dealer or any other remedies you folks may know of?
Thanks! |
Duct tape.
Originally Posted by _Me2_
(Post 10903972)
Duct tape.
Nae, it wont. I seen quite a few peeps with the same problem. Some feel that the use of one or a few large zip ties will do the trick. Other than that there is a company out there who sells the replacement plugs, or a new harness from Ford.
I have a zip ties on mine that did the same thing.
Originally Posted by NewToDiesels
(Post 10904627)
Ford must have made that bracket a POS, since it seems that many are also having that problem...or perhaps the heat in that area makes them brittle? |
Probably heat. You know how plastic is. I have two zip ties (standard stuff from Lowe's) together to make it longer so it will wrap around the FICM. I have 4 ties total making a two-tie (for length) 'strap' on both sides of the connector. My plan is to get the larger industrial strength ones, but these have been fine for the last 6 weeks since I installed them.
I also did the ziptie repair.
The one on the left in the first pic below would slip off so it now has an additional ziptie linking the two to help keep them in place. http://i897.photobucket.com/albums/a...30811_0004.jpg http://i897.photobucket.com/albums/a...30811_0002.jpg |
They have really cheesy clips on those plugs. One of mine has a broken clip, both the second clip holds it well. I wish they had used the cam-style clip like on the PCM plugs.
I always thought I was the only one that was heavy handed and broke it... I feel so much better now :-X21
(Post 10905003)
I also seem to have a knack of picking up the wrong part at the store when ever there is a choice of more than one. - Sometimes I just buy 1 of every type because I live so damn far from everywhere :-X03 |
(Post 10905003)
The zip tie gang - we need a logo.
(Post 10905003)
Originally Posted by npccpartsman
(Post 10906253)
LOL--you're not alone. Add me to the list. I absolutely HATE taking a FICM out and I've done it several times. It never seems to get easier.
