Fuel Filter/Water Seperator
I am getting ready to change my fuel filters in my 05 F250. How long do I let the water separator drain for? Until it stops draining? Also, what is the tool I need for removing the fuel filter from the rail, and where can I buy it from? Thanks in advance for any help.
Originally Posted by usmcknight69
(Post 10903695)
(Post 10903695)
This is the type of socket I use on the HFCM & oil filter cap (they're the same). http://www.amazon.com/Lisle-14500-Oi.../dp/B000JFL7ZS |
bottom one is 36mm.
the top one, i have a 15/16 scoket that fits perfectly on the top filter cap. |
I drained my water separater today to I just let it run untill it stops then unscrew the filter cap and change the filter
make shure to lube the o-rings and when you get it all back together make shure you Cycle the key but do not start engine cycle the key 3-4 times for 30 seconds or so to purge any air in the system out and you will be good to go and then start it up |
Make sure you get ford fuel filters because the other filters I have seen do not have the water-wicking sock on the fuel water separator filter unless you have excess money for a fuel pump and injectors.
Thanks for all the help. That is the tool I was looking for, now I just need to order one. Appreciate the quick responses.
(Post 10906322)
Tanks NPC, Looks like ill be heading to sears tomorrow
(Post 10906389)
Originally Posted by npccpartsman
(Post 10906360)
36mm deep socket 1/2" drive from sears for <$10 fits oil filter and primary fuel filter on the frame. Secondary fuel filter is 24mm--DO NOT use the 1/2" square hole in that lid or you will break it.
Originally Posted by Snuggyworm
(Post 10907287)
@ npccpartsman, wat do u mean by "do not use the 1/2" square hole"? wat 1/2"? do u mean not to use a 1/2" driver?
Originally Posted by zhilton
(Post 10907298)
In the top of the secondary fuel filter housing you can stick a 1/2" drive ratchet...don't do that. Use a 24mm socket that will fit on the hex of the cap.
since i torque everything back to ford's specs, i keep a torque wrench tats a 1/2" driver. |
(Post 10907327)
wow. i jus learned something again! i remember using a 24mm socket for the top & 36mm socket for the oil filter and fuel filter below. its been a while. i never knew tat u could fit a 1/2" socket. so jus to confirm for the top fuel filter, 24 mm socket with 1/2" driver/wrench is ok?
(Post 10907350)
Yes, 24mm on the secondary cap; 1/2" drive is ok. But it's not the socket...it's sticking the actual ratchet (w/o a socket) into the 1/2" square opening that will get you into trouble. You pretty much either have to use a 1/2" drive socket or a box wrench to get the cap off. Maybe Lesile will come out with a 3/8" drive 24mm like they did for the oil filter/HFCM cover.
btw, u got my curiosity. u mean the 1/2" ratchet can fit into tat hole?? i never thought bout it. lmao. no sir, i wont be tat dull to try it. :-X19 darn plastic thing might crack on me and my wife will tink it's my excuse to try to spend extra money. :-wink thanks for clearing tat up anyway! |
i tink the torque settings should be 24 lbs / ft of torque, i tink. kinda of a ford standard for them plastic covers, me tink.
