2 or 4 wheel abs?
Dont have my truck here right now to check, but does anyone know off hand if its 2 or 4 wheel ABS? need to pick up some rotors.
2001 F350 Super Duty Crew cab 2WD diesel Thanks! |
It was optional, the only real way to tell is if it has the wiring going to the hubs, rotors should be the same regardless though.
Guess I will wait and double check.. The place I was going to order them from wants to know before they ship them. Thanks, Jason |
I know the rotors are different for 2WD vs 4WD but I didn't think there was a difference in whether or not you had RABS or 4WABS
Thats what I thought.. The connector is not on the rotor, but the caliper right?
Originally Posted by BigAlsPSD
(Post 10831578)
Is 2 wheel ABS on the front or back? |
Originally Posted by PEI
(Post 10831586)
If its 4wd with 4WABS you should have one line running to the caliber, one line running to the ESOF (if you have it) and one line running to the top of the hub
Originally Posted by Bobbys Big Red Rig
(Post 10835305)
That's good if you didn't buy the truck pre-owned and the previous owner had replaced hubs once before. Hope that came out right:-X04. I had the same question. Is there a way to know if you have 2 wheel or 4 wheel ABS? I am the third owner of my truck and second owner had replaced huds once, left a few parts out. He went with the ones with ABS connectors because they were cheaper and in stock, the cut the connectors off. He said he "thought" that was the same way it was when he got it. I went with the hubs without the connectors because I did not notice the way he did the old ones until I got them off.
Is 2 wheel ABS on the front or back? I have only 2WABS, rears only, I too have the hubs with the sensor installed wiring cut off, so that I can grease them yearly, the connectors for the front ABS are at the rear of the inner fender, and are not connected to anything on mine, I guess if someone installed ABS hubs and ran the wiring it could appear to have front ABS, then you would need to look at the ABS module under the battery on DS. |
As I discovered today, there IS a difference between rotors for a early 99 with ABS on the front and without ABS on the front.
The early 99 with NO ABS on the front has a smaller diameter spindle. An early 99 WITH ABS has a larger spindle. The rotors for one will not fit another. This is disappointing to learn after you have jacked the truck, removed the brakes, and removed the rotor. I can't speak for other year models though.... If you have ABS on the front, you will have two lines going to the caliper. One for brake fluid and one for the ABS. If you do not have ABS, you will have only the brake fluid line going to the caliper. |
Can I assume this statement is referring to 2wd rotors/spindles? 4wd rotors should be the same, 99 and up right?
Originally Posted by bigtexan99
(Post 10836631)
Originally Posted by dfoxengr
(Post 15262141)
However, the Hubs remain unchanged other than the ABS Sensor. Which, can be used on ABS / Non-ABS Systems. There is only wiring, which signals the ABS Module and it (ABS Module) limits the pressure pulsation. |
(Post 15262141)
https://www.ford-trucks.com/forums/1...e-factory.html |
