hood latch for 73-79?
the hoop that bolts to the hood or its counterpart main latch bolted to the core support ???
I should have them both...post your email and we can go from there. - cs65 |
Originally Posted by camperspecial65
(Post 11371606)
Just an update...I have pairs of door scuff plates for both 65-66 cabs as well as the earlier step in type cabs like used throughout 61-64....
Door trim for the upper door panels, radio/speaker parts for 61-66 trucks(radio is used in later year E,C series as well as Bronco through 1977) I have the RH dash surround trim for 73-79 in metal with the black insert color or woodgrain as was used on certain upper trim levels. I also have the lower switch trim plate originally used on 1963-64 Custom Cab trucks as well as a driver grade dash bezel for the same trucks which had the round speedo. I also have a black dashpad for 73-9 as well as a few glovebox nameplates for them as well as the trucks back to 1967. I have much more especially for the 61-66 trucks so nothing is too small to ask for. - cs65 |
Hey cs65 - haven't ever gotten a response via email. What's up?
Odd...I have sent 2...I have it boxed up..
PM me if you want... - cs65 |
Looking for a hood for my 62 F100 Uni.
I have a PERFECT hood...undrilled except the center badge...Im about 2-3 hrs north of you depending on how heavy your right foot is :-)
- cs65 |
***Another update on stuff...I now have a perfect spare tire cover panel for the Super Camper Special trucks as well as fender badges for the same. I also have a chrome dash bezel for the 61-66 trucks with the round speedo. It has been punched for the accessory alt/oil pressure gauges.
Ive got additional door pouches and trim rings for 61-66 as well as door trim and scuff plates for 61-66 trucks(both types of scuff plates) - cs65 |
(Post 11437275)
- cs65 |
can you call me about the hood 1-773-965-5483 Joe
cs65:
You wouldnt happen to have a front and rear bumper around for a '65? |
whats your email Bronco ??
- cs65 |
email
(Post 11442169)
- cs65 |
How much for the spring loaded emergency latch for hood and scuff plates for a 64?
