Originally Posted by Jolly Roger Joe
(Post 11057725)
Thanks Wayne. I've decided I'm not going to install it on the truck until I get the new ends, as it doesn't make sense to do that twice. I'm not driving Betsy yet, so there's no rush. And I found the tie rod ends for $40 at NAPA online.
After I straightened it as best I could, I made the toe adjustment with the original "bent" tie rod using only a tape measure to get the front and back of the tires even. Is there a better way to do this without the special tool in the Shop Manual? Or is this something I'm going to need to take it somewhere to have done correctly? |
Originally Posted by raytasch
(Post 11060238)
A tape works. I use a piece of thin wall tubing with a dowel rod inside and at one end. Something like vice grips on on the tubing to hold an adjustment on the dowel rod and you have a pretty darn accurate way to check toe. Both pieces I had on hand.
(Post 11060208)
Sam, I have a 4" wire wheel. I started with that in my drill, but it was taking forever, so I resorted to the manual labor/putty knife scrape method. :)
Originally Posted by speedyweasel
(Post 11088650)
This is the part where we both say, "man, I could really use a good blasting setup right about now."
I learned something from 52 Merc indirectly when I got this part from him. Instead of fighting with the remaining old tie rod end (which I have not tried to remove yet) I think I'll just cut it off. Gonna replace it anyway... :-jammin |
Tis the season...
Since she's not going anywhere, I decorated Betsy for the season.
https://cimg2.ibsrv.net/gimg/www.for...e4d342890b.jpg |
Atta Boy! she looks great!
(Post 11105018)
(Post 11105463)
She looks ghostly. Any comments from the neighbors?
LOL That is AWESOME! I love it! Puts new meaning into 'yard art'!
Thanks guys.
If I get a lighted Santa or snowman to put in the cab, I'll post another pic. My wife loves the idea. And since I hope to have Betsy road worthy before NEXT Christmas, this may be the last time I decorate her. But... maybe not. |
I borrowed my son's timing light a few weeks ago, and tried to set the timing. But even with the distributor cranked to the stop, I couldn't make the marks line up. It was too far advanced, and was harder to start.
Then I read this reply from 38 coupe in another thread: "I set the timing at TDC (0 degrees) with the engine off. Turn the engine by hand until the pointer is aimed at the "bump". Pull the distributor cap. Loosen the distributor. Turn the ignition on. Start with the distributor at full retarded and slowly advance it. When the points spark, stop turning the distributor and lock it down. No timing light needed." I made sure the rotor was pointing at #1 plug ( it can point 180 out with the timing marks lined up) although I doubt it makes a difference, and followed these instructions. The truck starts easier and runs smoother than it has since I got it. And rather than turning the engine by hand, I used the button on the starter relay to crank the starter. If you do use this method, make sure the ignition key is OFF and the truck is in neutral before pushing that little button. :-X0A6 |
Yeah i can't seem to get my timing light to work right on my '53 Mainline (215 Inline 6) I know it's a good timing light as it works on other stuff. I wonder if it being a 6V system, if that throws the light off. I ended up just setting it by trial and error. Will have to try your method next spring when i pull it out of it's cocoon.
But it there any truth in that? Do you have to use a timing light specific to a 6v system? I noticed the same thing with my dwell meter too. Was giving me weird readings... ended up just setting by gap. And input on this? |
Originally Posted by Dano78
(Post 11111537)
But it there any truth in that? Do you have to use a timing light specific to a 6v system? And input on this?
I bought an old Snap-On 6V timing light at an estate sale over the summer for $5. Works like a charm.
So, does it make a difference if it's a 12v timing light? Does a 12v timing light not work on a 6v system?:-huh
EDIT: I Googled it and came up with this... http://www.stovebolt.com/techtips/timinglight.html |
