New member, new project
Hello all, I am new to fixing these old trucks and found my first project hidden in the eastern slope of the Sierra Nevadas and sitting for 10 years. It wasn't running and had a broken rear axle but I got a real nice deal on it. It has the stock 352 and 4wd.
https://www.ford-trucks.com/forums/p...ictureid=76758 My brother was kind enough to tow it home for me and it took my Jeep in 4lo to push it up the driveway and into the garage. So far I have rebuilt the rear axle, I needed to have the third member rebuild and had to find a replacement axle shaft. I have rebuilt the entire brakes and replaced the master cylinder. https://www.ford-trucks.com/forums/p...ictureid=76760 The engine has required the least amount of work. We had to figure out how to eliminate the second battery, as it had a second one installed to help power a winch. Other than that I had to rebuild a carb, I did a ton of research beforehand as I have never touched a carb before. Then just basic replacement of fluids, plugs and wires it started back up. I still have several issues to fix, including a bit of death wobble when I hit a bump at speed, and figuring out the 4wd system. Speaking of which, in the picture above I appear to having a blown out part attached to the firewall. I have no clue what the name is. If anyone knows that would be helpful. Cleaned up rims. https://www.ford-trucks.com/forums/p...ictureid=76764 As of now I am starting some bodywork and finding a source for a hood. This is something I have never done. But with research, which this site has helped via lurking in the past, I am sure I will be able to be successful. https://www.ford-trucks.com/forums/p...ictureid=76759 |
Looks good, you'll have a blast with it.
Welcome! Nice project!
Cool! Nice truck! Thanks for sharing.
The rims look brand new. Good work! That's a nice mountain rig. Lots of potential there. :-X22 What year is the truck and what do the fender emblems say?
The year is 1966. The fender emblem are missing however the image was burned into the plexiglass saying four wheel drive.
I am still at a loss at to what that blown out part is on the firewall of the engine picture. She does look nice next to my '06 F-150. |
Those are the correct fender emblems for the truck. Consider keeping the bright colors and not speeding too much lol. :) There is probably no AC, but does the heater work?
Originally Posted by Irrational
(Post 10667580)
(Post 10667580)
Nice....gotta love those 4WDs
Nice find. Great that it runs after sitting for 10 years. I wasnt that luck with my 65. Motor was siezed up solid. Probably why they stopped using it. Enjoy the 4x4 welcome to the club.
Originally Posted by 37 Ford guy
(Post 10667689)
Cool truck! The mystery part is hard to see in the pic but it sorta looks like a vacuum diaphram from an old style cruise control setup. Are there any other indicators inside the truck that would suggest it may have had an aftermarket cruise control installed at one time? Some closer pics would definitely be helpful.
And for Wills, I've been bouncing two different color schemes around for awhile. The first is a hunter green and cream, while the second is an orange cream (think creamsicle frozen treat) and cream. I also have never used an old 4x4 in this style before. I assume stick it in neutral, get out and lock the hubs, then move the transfer case lever to 4wd? I am just afraid of breaking anything to try it. |
I think the orange and yellow looks pretty good so I vote orange and I'll have one of those frozen treats. :) If you haven't already done it change the transfer case fluid, put the front end on jack stands and test the full range of the transfer case and the locking hubs. Make sure the front wheels engage and disengage as they should in four high, four low and two wheel drive. Then you can move onto the road test. You won't break it as long as you don't go on "Monster Jam" with it lol. :)
(Post 10666164)
https://www.ford-trucks.com/forums/p...ictureid=76758 My brother was kind enough to tow it home for me and it took my Jeep in 4lo to push it up the driveway and into the garage. So far I have rebuilt the rear axle, I needed to have the third member rebuild and had to find a replacement axle shaft. I have rebuilt the entire brakes and replaced the master cylinder. https://www.ford-trucks.com/forums/p...ictureid=76760 The engine has required the least amount of work. We had to figure out how to eliminate the second battery, as it had a second one installed to help power a winch. Other than that I had to rebuild a carb, I did a ton of research beforehand as I have never touched a carb before. Then just basic replacement of fluids, plugs and wires it started back up. I still have several issues to fix, including a bit of death wobble when I hit a bump at speed, and figuring out the 4wd system. Speaking of which, in the picture above I appear to having a blown out part attached to the firewall. I have no clue what the name is. If anyone knows that would be helpful. Cleaned up rims. https://www.ford-trucks.com/forums/p...ictureid=76764 As of now I am starting some bodywork and finding a source for a hood. This is something I have never done. But with research, which this site has helped via lurking in the past, I am sure I will be able to be successful. https://www.ford-trucks.com/forums/p...ictureid=76759 Did you ever figure out what this was, or does anyone have any ideas? And also, what rims were stock for the '66 4WDs? I have white rims like the ones in the pic as well but am assuming that they're not Ford. I have the stock hub caps with the two front ones having the hup hole in the center that I'd like to use. |
Sounds like you might need a steering stabilizer for oversize wheels and tires. You might look into a wheel alignment, new shock absorbers, all sorts of front suspension parts worn out. If it were mine Id be looking at the front end for the problem. Death woobles dont occur unless something is worn out or broken.
