anyone got a write up on how to change the 4wd drive actuator out on a 2004-2008 trucks? thanks for any help
BlueOvalDude
07-27-2011 11:24 AM
Originally Posted by dfboothe
(Post 10626356)
dtboothe,
It's been so long since I've replaced a 4wd actuator on a F-150 but off the top of my head here are a few key points to the job: There should be 6 allen head or torx head screws retaining the cap. Once the cap is removed there will be a large 'C' clip inside, this may require special pliers to remove. Once this is done there are a series of collars and bushings that should be kept in order so as to simplify re-installation.
Don't forget to grease-up all pivotal components upon re-installation. I'll conduct some research later when I get home from work so I could supplement these tips. Hopefully some other forum members will be able to more thoroughly address your question before then :-X03
xjcamaro89
07-27-2011 01:25 PM
Dfboothe, you talking about the vacuum OWE actuator behind the steering knuckle out at the wheel
xjcamaro89
07-27-2011 01:26 PM
I meant IWE actuator
dfboothe
07-27-2011 05:23 PM
yea i checked that and it won't hold vacuum
so i'm pretty sure it needs to be changed
