6.4 Bio Diesel ???
Will my 2008 F250 6.4 run ok on a Quaility bio Diesel? Commercially produced from New raw materials. B10, B20, B50, B100??? I have heard alot of folks are scared. What are the reasons to be scared? Is it safe?
motor is rated for up to 5% that is it. Anymore, I believe will ruin the emissions components as they were not designed for any higher of a percentage.
Also be aware that you must follow the severe duty maintance schedule. Should be anyways. Bio also produces less energy, therefore less mpgs. Personally I'd stay away from it unless you can verify its quality and percentage. |
As usual, Scott is correct. Your motor is certified for up to B5 and no more. Biodiesel is known to cause a whole host of problems with the fuel system, and these are particularly expen$ive with a 6.4L engine.
Stay away! :eek: |
See my write up posted on December 13 or 15 on the EPA test results of biodisel on diesel engines with DPF technology. I am convinced that using bio results in the engine making oil during regeneration. The EPA agrees. I am also convinced that while diesel fuel in the oil will boil out, there by reducing dilution, bio will not. The EPA agrees. I am convinced that using bio regularly will cause premature engine failure. The EPA does not agree but in their report they say that "use of bio did not cause significant engine damage even when used in our test vehicles for 200,000 miles, which is twice the expected life of a diesel engine". So, if your expectation is for a 100,000 miles then I guess you're OK. In fairness the tests were not run on the 6.4L or any other large engine as far as I could tell. So, read the report and draw your own conclusion. As for me I avoid bio every time I can and have gone to a radical oil program to combat oil dilution. And when I get home from this trip the DPF is coming off. Hope this helps.
My experience with bio has been negative everytime I have used it. Many of the Loves stations, if not all use B5. The last time that I used B5 was in the Houston area. Bought fuel at a Loves, it said B5, I had changed fuel filters 2k before. By the time I got home, the truck just seemed lazy. I changed filters and topped off and also used my usual dosage of Diesel Kleen, after driving back and forth to work a few days, it seemed back to normal.
My reccommendation, avoid bio, good idea, bad results and it could cost you a lot more than the few cents you save. |
Originally Posted by Gearitis
(Post 10607162)
I changed my vacation plans this year and did no go to Minnesota, due to their mandate that only bio-diesel be sold. The life of my truck/engine/emissions etc. is more important than fishing in Minnesota.
minnesota biodiesel - Google Search |
Originally Posted by WhiteEx
(Post 10627738)
(Post 10627738)
I seriously looked at the 67 gallon tank a few months ago, but decided against it. The disadvantages are the price (~$1000), carrying around the weight of the additional fuel (over 100 lbs), and the added risk of condensation in the tank if not kept full.
I can get from Duluth to Warroad on one tank, and Canada's Lake of the Woods has, in my humble opinion, the best muskie fishing anyway. On long trips I usually carry several 5 gallon cans of fuel, just in case I can't find a truck stop, but that is a pain. |
(Post 10631134)
I can get from Duluth to Warroad on one tank, and Canada's Lake of the Woods has, in my humble opinion, the best muskie fishing anyway. On long trips I usually carry several 5 gallon cans of fuel, just in case I can't find a truck stop, but that is a pain. I'm still considering the 67 gal tank myself, if it was $500 it would already be on the truck. I'm probably not going to be doing many more long trips, so it's becoming harder to justify the extra cost. |
in BC B5 is the law, my 6.4 has run it for 25+k mi and its fine. i did however start using ford cetane booster or ps diesel kleen for the past 20k and its all good. we had the motor torn apart and everything was good. now if it was up to me id want just reg diesel but since im forced to use b5 i havent noticed a difference. i also do fill up at a Husky station which offers "Diesel Max" which is B5 plus added cetane booster and whatever other chemicals they use to make a "premium" branded diesel. You will be fine running B5 diesel
Originally Posted by pog23
(Post 10632117)
(Post 10632117)
That alone tells me just get the good stuff and stay away from it. In addition, since at least here in the lower 48 one cannot truely expect it will be the 5% vs some other known percentage I think it best to stay away from it if possible. |
Originally Posted by wp6529
(Post 10632202)
Why exactly was the motor "torn apart" if everything was good? Ford clearly specifies that the severe duty maintenance schedule must be use if using *any* biodiesel, up to the maximum of B5, and warns not to use anything over B5. If Ford has a problem with it, so do I.
