I just bought a 96 F-150 w/the i6-300 and 118k mi on it. It's got the M5OD and 3.55's and IMO it gets up and goes just fine. Didn't even notice a small 3k load behind me when I was towing some stuff through a buddies field. I mostly drive it on the street or through woods to go fishing at a buddies pond and its got more than enough oomph. Even buried the speedo once or twice ;). It's not the fastest thing out there but if you really gotta get going you can romp her up to about 3800rpm in each gear and you will accelerate pretty fast.
I can't imagine it with an automatic though... For reference, I also drive a 05 Mustang GT with some minor boltons so I know what fast & slow are haha. |
I would avoid 3800rpm like it was the plague with a 300 six cylinder...
That's about the highest I'll ever go with her, she sounds like a locomotive at that RPM haha. I don't even want to know where limiter/redline is on this sucker.
^^^^^agreed!
i always shift at 3k rpm if im gettin on it...even then it sounds like the ole' girl is at 5k lol. i CURRENTLY own both. 1988 f150 lariat 4x4 5 speed 302 5.0l 1994 f150 xl 2x4 5 speed 300/6 4.9L I can honestly say that the 94 is my dd. It gets me where i need to go, gets good mileage....for a truck (around 17 mpg). It can haul small loads and not complain. And it seems that no matter if im driving around town, on the highway or hauling a load..The mileage stays exactly the same. Its a gutless wonder but its reliable, cheap to fix, easy on gas, and can haul an average sized load. What else do you need in a daily driver truck. On the other hand, the 5.0l is a great motor. It has a little less ass from the start but it will pull just as much, if not more than my 300/6. The only difference is, the gas mileage drops fairly quick when you put it to work with the same sized load. That being said, the 302 is about the same on gas as the 300 just daily driving. The 302 has a HUGE market of aftermarket parts if you wanna make a few extra horses for cheap where as the 300 only has a select few vendors for aftermarket items at a slick price. In conclusion, MY opinion is this: If you want a good, reliable truck that you can putt around town in, not have to worry about if someone elses truck is faster or has that glorious v8 sound or one that will cruise down the highway at 65 comfortably....Grab yourself a 300/6 ford If you want a truck that can be used as a DD or a toy but can run with most stock trucks, have that v8 sound everyone longs for, something you can build up and gear out to make some good horses, lift up with some big tires and wheel around at 4k rpm's with no problem, then go out and find you a ford with a 5.0l! im sure some will not agree but this is an OPEN discussion to ALL opinions and thats just my theory! |
^^^ My 300-six is my lifted truck. It cruises down gravel roads going 50 at around 1700rpm and still gets me 15mpg. Can't ask much more out of a lifted pickup.
Wish I could see a decent mpg out of my 5.0 best iv got so far is 11
I noticed a couple mentions of 5.8s. Everything I've read about the 300, pulling hills at 1500rpm or whatever, a 351 will do just fine, then pull away from both a 5.0 or 4.9 at higher speed. Anyway, I have a 5.8 and love it, good torque and more power than either 4.9 or 5.0 at a very good compromise of rpm. 70mph and its at 2000, and it'll do that with a 5k trailer. Click overdrive off and it will accelerate up a hill with that same trailer. No bs, I consistently get 17mpg empty (235/75R15 with 3.55:1.
Its the stroke of the motor that really makes the torque, gives the piston more of a moment arm on the crankshaft. The 4.9 has a 3.98" stroke with 4.0" bore, but has just the 6 cylinders, makes its pk torque pretty low. The 5.0 has a measly 3.0" stroke with a 4.0" bore, makes its pk torque relatively high (relative to these 3 motors). The 5.8 sits in the middle of these two motors, 3.5" stroke and 4.0" bore, and makes more torque at 2000RPM than either the 4.9 or 5.0 do at any RPM. Anyway, I know the 5.8 isn't really in the OP's ?, just like talking about it:-X06. Oh, doesn't the 300 have 7 main bearings? Instead of the V8's that just have 5? Could be entirely wrong here, just thinking of longevity. |
Originally Posted by ryito1122334455
(Post 10586048)
wow, i really learned allot, ferrari had a straight 8....interesting that the 6 is way more reliable tho, due to vibrations from "crankshaft whip" on the 8's
I've always wondered how one would perform in one of our trucks...not to mention how it would SOUND... if it could even be shoehorned in, that is... those suckers are looong. Back in the day, it wasn't uncommon to have hoods that were longer than the passenger compartments. I know where I can get several of them, but the cost of rebuilding them would be prohibitive. I have to say, though...the thought of an old '30s straight 8 crackling through straight pipe stacks is tantalizing... Anyway, as far as reliability goes, someone made a comment earlier about the cylinder orientation of a straight six contributing less to wear than a V engine. I believe this to be absolutely true. In a V engine, there is more friction between the pistons and outboard cylinder walls because the pistons are constantly "laying down" in the cylinders. Basically they are resting their weight on one part of the cylinders more than anywhere else. In a "true" straight six ("true" meaning 90 degrees to the ground), the pistons are standing up in the cylinders and not tending to rest themselves on any one surface of the cylinders themselves. I think there is inherently more balance in an inline six as well, which aids in longevity. Of course, there are many things that contribute to the overall reliability of an engine other than its cylinder arrangement. Make no mistake... there have been some crummy sixes made over the years. Some, like the Jeep OHC 230 Tornado, were too advanced for their time and didn't fare well as a result. But consider this...why has the inline six been the overwhelming configuration in the OTR truck industry for decades upon decades? There must be something to that. |
Originally Posted by Growl60
(Post 10584232)
Ive owned my 302 for close to two years now in my 94 with 142k on it. It had 119 when I got it. I take 50 mile trips on the highway with it twice a week. I love how smooth it is and it definately has no problem keeping up on the highway. It gets great mileage for a full size truck. It will out run a 318 or a 305 any day of the week. The only con with the motor I have is the pulling power. Ive pulled trucks bigger than mine on trailers with this truck. Ive had zero problems, its just the low end torque isnt that great but thats to be expected with the 302. I am not complaining, it still got the job done with no problems.
Originally Posted by dieseltruckjunkie
(Post 10584142)
good point, the 4.9 is best with a 5sd
The only thing I really don't like about the 302 in a truck is that fact that it often looses speed on hills or needs to down shift to passing gear at highway speed around 60-70 mph. If your going faster than 70 its usually not an issue. This is because of the power band.
Originally Posted by big-ugly
(Post 10588770)
i do agree that a lifted 300 is a beast. Hell, i wanna do it to mine. |
1995 f150 supercab shorty 4x4. 4.9l Inline 6 cylinder w/ m5od mazda trans. 4 inch rough country lift with 33" goodyear duratracs.
4-low in second gear all day long, she'll go through anything. My friends all laughed at me for buying a 6 cylinder, until we went mudding. Now they don't laugh anymore, but they do like to give me crap for having 6 instead of 8. |
I drove a 300/6 yesterday. 1989 f-150 2wd regular cab short bed 5 speed and around 190k miles. It reminded me why I swapped to the 5.0.... With the same 3.08 gears my donor truck had, the 300 seems lazy. We have a lot of hills around here and even on the smaller hills I was flooring it or downshifting to try to go the speed limit. That doesn't work for me.
So most of you that say the 4.9 is better, it's only because of where the torque is? I don't feel like this is a reasonable arguement... We can make a 10hp Briggs lug around whatever we want if we have enough gearing. For this of you with 5.0s saying it has no low end, how about gearing it properly? Many of us have said that over and over. A properly geared 302 is a whole different animal to drive. IMO a 300 will never out perform a 302 for me and my needs. I drive my truck on the road. It doesn't sit at home at putt around a farm. I get annoyed very quickly if I can't accelerate up hill or if I have to downshift to hold speed. I guess most of you making the 4.9 seem like it's some kind of beast dont have many hills or pull much in hills.. The 300s are really reliable engines and run fair, but I think the hype has gotten out hand.. |
as a firm beleiver and lover of the 300, ill have to agree with you strokin_tatsch.
If my 300 was worn out, id most likely swap in a 5.0 but it would be stupid to tear out a perfectly good motor right?? |
