Vin decode #4
(Post 17750472)
Would you type 4 individual posts with one picture in each please. The way you did it makes it hard to decode properly.
VIN: F25YLH99946 WB:131 Color:Y Model:F254 Body:C 4 Trans:G Axle:38 GVW:6900 HP:170 RPM:4400 DSO:44 Thanks again for your invaluable help. https://cimg0.ibsrv.net/gimg/www.for...30ec591e61.jpg |
Vin decode #5
(Post 17750472)
Text version: VIN:1FDNF6OHOHVA05559 DSO:415378 WB:153 Type:F60220 Body:HK8 Trans:AA Axle:TFM Once again, thank you. https://cimg6.ibsrv.net/gimg/www.for...dbe99b545f.jpg |
A = 240 1V I-6. C = Oakville Ontario Canada Truck Assembly Plant. G57020 = 1970. 156" Wheelbase. G = Chrome Yellow. F504 = F500, 18,000 lbs. GVWR 4 8: 4 = Charcoal Black Kiwi Vinyl & Charcoal Black Diamond Basketweave Vinyl / 8 = 81A Standard Cab. A = New Process 435 4 Speed Manual Transmission. 64 = Rockwell model F106 Rear Axle / 6.80-1 / 15,000 lbs. Axle Capacity. 18,000 lbs. Gross Vehicle Weight Rating. 114 net HP @ 3,800 RPM 410022: 41 = Chicago IL Ford District Sales Office, where the original selling dealer ordered the truck from. 0022 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot." |
E = 361 2V or 4V FT engine. V = Kentucky Truck Assembly Plant. W28999 = 1975. 158" Wheelbase BC: B = Light Blue / C = Pure White. F703 = F700 (gas); 23,000 lbs. GVWR 4A8: 4A = Black H/D Vinyl / 8 = 81A Standard Cab. 2 = Clark model 282V 5 Speed Direct. E2M: E2 = Eaton model 16244 Two Speed Rear Axle / 6.17/8.58 / 17,500 lbs. Rear Axle Capacity. M = Ford 7,000 lbs. Capacity with Power Steering. 23,000 lbs. Gross Vehicle Weight Rating. 41 = Chicago IL Ford District Sales Office, where the original selling dealer ordered the truck from. |
Y = 360 2V L = Michigan Truck Assembly Plant. H99946 = 1970. 131" Wheelbase. Y = Reef Aqua. F254 = F250 2WD; 6,900 lbs. GVWR C 4 = Pastel Parchment Corinthian Vinyl & Pastel Parchment Kiwi Vinyl. G = C6. 38 = Dana 60 Rear Axle / 3.73-1 / 5,200 lbs. Rear Axle Capacity. 6,900 lbs. Gross Vehicle Weight Rating. 170 net HP @ 4,100 RPM 44 = Twin Cities MN Ford District Sales Office, where the original selling dealer ordered the truck from. |
I have a 1962 f 500. Hard to find info on this so far. Vin- f50JK230035 for axle it says 32 trans - F i know it originally had a 6 cylinder, it it now has a 8 cylinder. I want to pull motor and tranny and put new seals in, they both operate fine, just leak. |
Originally Posted by Mac-Hine
(Post 17766374)
I have a 1962 F500. Hard to find info on this so far. VIN: F50JK230035 / TRANS: F / AXLE: 32 I know it originally had a 6 cylinder, it it now has a 8 cylinder. I want to pull motor and tranny and put new seals in, they both operate fine, just leak. J = 223 1V I-6. K = Kansas City MO Assembly Plant. 230035 = 1962, assembled November 1961. F = Borg-Warner T-98 4 Speed Manual Transmission. 32 = Timken model C100 Single Speed Rear Axle / 6.20-1 / 11,000 lbs. Axle Capacity. The swapped engine may be a 292 Y block, as it was an option in these trucks. The distributor is behind the carburetor. |
1986 F350 Vin# 1FDJF314GKAxxxxx
WB - 161 TYPE GVW - F378 BODY - DD8 TRANS - P AXLE - 65 SPRING - K5 EXTERIOR PAINT COLOR - 9M DSO - 23 Thanks in advance! |
Originally Posted by Hawkshaw59
(Post 17771682)
1986 F350 VIN:1FDJF3714GKAXXXXX
WB: 161 / TYPE/GVW: F378 / BODY: DD8 / TRANS: P / AXLE: 65 / SPRING: K5 / EXTERIOR PAINT COLOR: 9M / DSO: 23 J = Class H Hydraulic Brakes, 9,001-10,000 lbs. Gross Vehicle Weight Rating range. F37 = F350 2WD Cab & Chassis. 1 = 6.9L Diesel. 4 = Check digit, FoMoCo usage only. G = 1986. K = Kansas City MO Assembly Plant. AXXXXX = 1986 Numerical Sequence of Assembly, the trucks specific serial number. 161" Wheelbase. F378 = F350 2WD Cab & Chassis, 10,000 lbs. Gross Vehicle Weight Rating. DD8: DD = Scarlett Knit & Vinyl-Full Width Seat / 8 = Regular Cab. P = Borg-Warner T-19 4 Speed Manual Transmission. 65 = Sterling 10.25" Rear Axle / 4.10-1 / 8,250 lbs. Rear Axle Capacity. K5: K is the code for the front springs, 5 is the code for the rear springs, but all FoMoCo lists are the part numbers, not the load rates. 9M = White. 23 = Memphis TN Ford District Sales Office, where the original selling dealer ordered the truck from. |
My bad, I missed one sorry. It has a 6.9L diesel in it.
1FDJF3714GKA87xxx Maybe this will clear it up. Thanks. |
(Post 17773823)
1FDJF3714GKA87xxx Maybe this will clear it up. :-X22Thanks. |
1969 n600 napco conversion
Hey Number Dummy! I've got another truck to decode if you would. Has 4x4 conversion.has Napco emblems on the cowl. I can't get the pics to upload for some reason.
Vin N61EUE73393 WB 181 COLOR U MODEL N611 BODY 4281 TRANS M AXLE 53A 22000 GVW CERT UP 182 AT 3800 DSO 74 |
2 Attachment(s)
This is friend of mine work truck. I will be doing a little maintenance to it.
It' more modern then some of the others. 1FDNF80C8WVA09789 |
Here are the pics for the 1969 N600 Napco
3 Attachment(s)
This is the truck I was looking for info on.
