Originally Posted by matt113
(Post 17740037)
Redwood City, bay area
Call Marty @ SoCal Truck Wrecking here in LA LA Land to see if he has a user: 323-587-3144. SoCal is closed on weekends. |
Thank you! I will
F700 numbers
Hey, so we just picked up a monster of a truck from the CL.
Would you be able to decode the numbers below and give me some insight on what I just dragged home please thank you 1963 F70MU470942 156 - F704 181A W E 25500 160 3800 720184 |
1963, F700 question continues..
Also, would the inner fenders, door glass, radiator support and hood be the same size or fit as the regular f100-350 size trucks of that year? thank again |
Originally Posted by Junkergarage
(Post 17742832)
Also, would the inner fenders, door glass, radiator support and hood be the same size or fit as the regular f100-350 size trucks of that year? thank again Door, vent glass and windshield is the same: 1961/66 F100/1100; 1963/69 N/NT500/1100; 1967/69 F800/1000. Back glass is the same as the above except for 1961/63 F100/250 Uni's with the wrap around window (most don't have it). Radiator support is the same: 1961 F700/750 from serial number 170,001, 1962/63 F700/750. Inner fender aprons are the same: 1961/65 F100/250 4WD; 1961/66 F350/700 & B500/750 (School Bus); 1966 F250 4WD Hood is the same: 1961/64 B500/750 (School Bus); 1961/66 F100/700; 1965/66 B500/700 (School Bus). |
Thank you very much for the info and help. I can start shopping for parts with this knowledge.
Regards |
(Post 17742758)
Would you be able to decode the numbers below and give me some insight on what I just dragged home please? :-X22 1964 F70MU470942 / WB: 156 / COLOR: Blank* / MODEL: F704 / BODY: 181B / TRANS: W / AXLE: E / MAX GVW LBS: 25500 / CERT NET HP: 160 / RPM: 3800 / DSO: 720184 M = 330 2V H/D FT engine (introduced in 1964, there was no 'M' VIN engine code for 1961/63). U = Louisville KY Assembly Plant. 470942 = 1964 Numerical Sequence of Assembly, the trucks specific serial number. (1963 serial number range: 325,001-445,000 // 1964 serial number range: 445,001-580,000). 156" Wheelbase. COLOR: Blank* F702 = F700 (gas); 25,500 lbs. GVWR 181A: 1 = Silver Gray Crush Vinyl & Light Gray Rib Vinyl / 81A = Standard Cab. W = Clark model 2621-V1 or 2622-V1 5 Speed Direct Manual Transmission. E = Timken model R141 Rear Rear Axle / 5.57-1 / 34,000 lbs. Axle Capacity. 25,500 lbs. Gross Vehicle Weight Rating. 160 net HP @ 3,800 RPM 720184: 72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from. 0184 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot." *When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order. This makes it a Domestic Special Order. Note: Compare this VIN that is stamped on the Warranty Plate to the VIN on the registration/title to see if they match. 1963/66: Warranty Plate riveted to the left door face below the latch. People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors. Note: If this is a 1964, I'll have to change the radiator support info. |
Bill, I have just posted a few pictures of the F700 in question. The vin tag and title do match. Perhaps the special order also included the motor?
Thank you |
(Post 17745920)
Thank you If the engine was a DSO, there would be no VIN engine code. I've never seen any example of this occurring with any of the 100's of VIN's I've decoded over the past 11 years here on FTE Note: Post #728: That's a 1964 Warranty Plate (VIN decodes to a 1964), and the pictured truck has a 1964 grille. Pink slip: Year first sold: 1963. This is probably correct, because new vehicle production begins in August of the previous year, but the year model 1963 isn't correct and it also says YR: 1971. :confused: |
Hey Number Dummy,
You helped me with some part numbers and information on my 1970 C700. Hoping you can point me in the right direction here. I want to swap rear-ends on my C700, it currently has a rockwell. I'd like to find something that I can get a tall ratio so I can run 65 or 70mph. It has a 6.8:1 in it now. Maybe an Eaton, then find an aftermarket ring and pinion kit?? Your thoughts????? Thank you in advance, Randy |
Four Vin decodes, please, thank you.
I have two trucks, with the possibility of getting two more. I would greatly appreciate it if you could decode them all for me.
F50ACG57020 F25YLH99946 F70EVW28999 1FDNF60HOHVA05559 I will attempt to attach pictures of all four plates/ sticker. Your invaluable help is greatly appreciated. - Mark https://cimg4.ibsrv.net/gimg/www.for...e5a340c787.jpg https://cimg8.ibsrv.net/gimg/www.for...3e43bbb522.jpg https://cimg3.ibsrv.net/gimg/www.for...59d2a2af92.jpg https://cimg9.ibsrv.net/gimg/www.for...1ad6a7a175.jpg |
Originally Posted by BTBBT
(Post 17750374)
Vin decode #2
(Post 17750472)
Would you type 4 individual posts with one picture in each please. The way you did it makes it hard to decode properly.
VIN:F50ACG57020 W.B. 156 Color:G Model:F504 Body:4 8 Trans:A64 Axle:??none??lol GVW:18000 HP:114 RPM:3800 DSO:410022 Thanks. https://cimg8.ibsrv.net/gimg/www.for...18ba95fc1b.jpg Thank you |
Vin decode #3
(Post 17750472)
VIN:F70EVW28999 WB:158 Color:BC Type:F703 Body:4A8 Trans:2 Axle E2M DSO:41 Thanks. https://cimg7.ibsrv.net/gimg/www.for...74f0109e80.jpg |
