(edited because Bill answered already)
Well I think I got it ran down thru another source, it's called a :
New OEM Ford Medium Heavy Truck Brake Camshaft Bracket Assembly New OEM Ford Medium Heavy Truck Brake Camshaft Bracket Assembly | eBay I don't know if I should proud or ashamed that I stumped you but I'm leaning towards shame because I was using bad description. Thank you for the help. |
Originally Posted by psmith0803
(Post 16804721)
New OEM Ford Medium Heavy Truck Brake Camshaft Bracket Assembly New OEM Ford Medium Heavy Truck Brake Camshaft Bracket Assembly | eBay E8HZ-2310-A .. Bracket Kit-Brake Camshaft-Right Rear / Obsolete 1988/89 F700/900 with Bendix 16 1/2" x 7" air brakes. Last MSRP: $660.85 - Dealer net cost: $429.55 / The ebay price is a roaring bargain, but the parts catalog description is a bracket kit, but I only see the bracket. But, if the truck does not have this type of air brakes, this is the wrong part number. |
Thank you for the warning! I'm going to double check the picture of the part against the part to make sure.
I appreciate all your help! Have a great day. |
Can you decode this one for me?
60ccej8815 146 F607 Ga8 A 65j 19700 150454 Thanks!! |
Originally Posted by tonymontanna1983
(Post 16813639)
F60CCEJ8815 / WB: 146 / COLOR: Blank* / TYPE/GVW: F607 / BODY: GA8 / TRANS: A / AXLE: 65J / MAX GVW LBS: 19700 / DSO: 150454 C = 370 2V or 429 4V C = Oakville Ontario Canada Truck Assembly Plant. EJ8815 = 1979. 146" Wheelbase. COLOR: Blank* F600 2WD (gas), 19,700 lbs. GVWR GA8: GA = Black Heavy Duty Vinyl / 8 = 81A Standard Cab. A = New Process 435 4 Speed Manual Transmission. 65J: 65 = Rockwell Single Speed Rear Axle / 6.83-1 / 15,000 lbs. Rear Axle Capacity. J = Ford 5,000 lbs. Capacity Front Axle with P/S or Ford 4,700 lbs. Capacity Front Axle with M/S 19,700 lbs. Gross Vehicle Weight Rating. 150454: 15 = Newark NJ Ford District Sales Office, where the original selling dealer ordered the truck from. 0454 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot." *When there is no COLOR code, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order. |
1998 F-800
Can you decode this Vin for me:
1FDWF80C9WVA21907 |
(Post 16804806)
Seller listed the part number:
Thank you numberdummy!! Your services are not taken for granted!!!
Vin/Info Tag decode 1985 F700 Dump
1 Attachment(s)
Posted this in the top of the forum but will cross post it here in hopes that NumbersDummy will see it and decode it for me.
Picture of Vin/Info tag are attached. I've decoded the vin using other tools and it comes up as an LN7000 which is flat wrong so I'm coming here to get it decoded correctly and confirm which A/T type/model is in it and what axle ratio it has. 1985 F700, 8.2L GM/Allison w/ A/T (Allison but which model)? Attachment 173737 Thank you in advance. |
Originally Posted by gdoakes
(Post 16940573)
N850
Hello Bill, im working on a 1969 N850 , I'm looking for the driveshaft carrier bearing, I found a part no.
D4HZ-4800-A, could you check to see if this is the right number and if this part is available anywhere. Thanks, Bill |
Originally Posted by shillinghillf600
(Post 16959474)
Hello Bill, im working on a 1969 N850.
I'm looking for the driveshaft carrier bearing, I found a part no. D4HZ-4800-A, :-huh could you check to see if this is the right number and if this part is available anywhere. If you aren't sure, post the TRANS code stamped on the Warranty Plate, riveted to the left door face below the latch. |
N850
Thanks for your quick response, the vin is N861LUE13318 trans code is blank but I'm sure it's a Transmatic MT-42, axle code is BKE, DSO is 549493. Thanks for your efforts, Bill
(Post 16959530)
