Thank You NumberDummy, you nailed it. At this point, the transmission is still in the truck and I am trying to get a fix on the repair costs. I believe (hope) the repair is just a clutch but I soon found out that without part numbers, I can't get too specific a cost estimate. If you could post the relevant part numbers and sources, I would again be appreciative. I had the clutch replaced a few years back, but the mechanic was unable to source some of the parts at the time and may have reused worn parts. I am thinking that is part of the reason I'm looking at a repeat. Thanks again for your rapid and on the nail response.
Originally Posted by Bumpalong
(Post 16607061)
If you could post the relevant part numbers and sources, I would again be appreciative. I had the clutch replaced a few years back, but the mechanic was unable to source some of the parts at the time and may have reused worn parts. I am thinking that is part of the reason I'm looking at a repeat. Thanks again for your rapid and on the nail response. Look at the pic and post the basic part numbers for the parts you need. |
Hello again NumberDummy, I apologize if I'm missing something. What I am hoping for is a relatively simple clutch replacement job involving a clutch disc, pressure plate, throughout bearing, and pilot bearing if required. I'm afraid I don't see any of these in the schematics you posted. Furthermore, the mechanic who did the last clutch said there was no more adjustment in the linkage which would often not disengage the clutch which resulted frequent gear grinding. If you could provide the schematic of that assembly, it would be helpful.The one parts guy I spoke with said he would require the part number of the pressure plate to see what he could come up with.
Also, so that I don't have to keep bothering you, this truck has a driveline emergency brake on the rear of the transmission that I would like to rehabilitate if possible. Any information on its parts would be appreciated as well. This is a secondary issue about which and I am not very optimistic however. Again, thanks for your help, I've voted up the thread and your reputation. If I see a ballot for most helpful truck guy, I'll be sure to vote for you as often as I can. Cheers |
2 Attachment(s)
(Post 16609578)
What I am hoping for is a relatively simple clutch replacement job involving a clutch disc (7550), pressure plate (7563), throwout bearing (7580), throwout bearing hub (7561), pilot bearing (7600) if required.
Furthermore, the mechanic who did the last clutch said there was no more adjustment in the linkage which would often not disengage the clutch which resulted frequent gear grinding. If you could provide the schematic of that assembly, it would be helpful.The one parts guy I spoke with said he would require the part number of the pressure plate to see what he could come up with. Also, this truck has a driveline emergency brake on the rear of the transmission that I would like to rehabilitate if possible. Any information on its parts would be appreciated as well. This is a secondary issue about which and I am not very optimistic however. Note in the upper pic where it says F100-250. The parts are actually the same as 1961/63 F100/250 4WD & 1961/63 F350/750. |
Vin help
I recently bought a 1973 F600 dump truck that originally was a U-haul. I don't know what engine is in it and I'm looking for the part number and size for a new flywheel for it. the VIN is F60DUR80579. Thanks in advance for any light you can shed on this. Rob
Originally Posted by DoubleS
(Post 16617085)
I don't know what engine is in it and I'm looking for the part number and size for a new flywheel for it. VIN: F60DUR80579 D = 330 2V Heavy Duty FT engine. Note: 1964/72, this was known as the 330 2V Medium Duty FT engine. 1973: The IDIOTS at FoMoCo dropped the original 1964/72 330 2V Heavy Duty FT engine, then renamed the former 330 2V Medium Duty as the Heavy Duty or Xtra Duty. :( U = Louisville KY Assembly Plant. R80579 = 1973. inre to the flywheel, the ring gear can be bought by itself or with the flywheel. C4TZ-6375-E .. Flywheel - Use with 13" clutch / 15" diameter - (8) 3/8" -16 pressure plate attaching holes on a 14 1/8" bolt circle / Marked: C4TE-6380-K or D2TE-6380-BA / Obsolete No Ford dealer or obsolete parts vendor has any. ------------------------------------------------------- C4TZ-6384-A .. Flywheel Ring Gear - 188 teeth / 1964/78 all 330/361/391 FT engines / Obsolete FEYER FORD in Edenton NC has 1 = 252-482-2144. KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241. GREEN SALES CO. in Cincinnati OH has 7 = 800-543-4959. CARPENTER NOS OBSOLETE PARTS in Concord NC has 30 = 800-476-9653. |
Thanks a five-ton numberdummy. I will get on the phone first thing in the morning.
Hey, quick question about gasoline for the 73 F600 truck, would you use 87 octane likely with ethanol or go with ethanol free gasoline? The later is about 40 cents more per gallon and I'm assuming the truck gets about 5-7miles/gallon.
I also heard that the interior parts for the F600 are identical to a F100 except for the steering wheel and panel. Any truth?
Hey Bill, what is domestic special order 0040? It's for my 1962 f250 4x4, 292, 4spend. Thanks, as always.
Originally Posted by wfo1955
(Post 16630443)
Some production figures are available, as these were kept for the entire auto industry by R. L. Polk and Co. |
I have a 1979 ford f700 with the 370 v4 engine and i need a vacum switch to pass california smog
Originally Posted by 1979fordf700
(Post 16638214)
I have a 1979 ford F700 with the 370 4V engine and i need a vacuum switch to pass california smog
1959 F600
I feel like every couple months I'm back asking NumberDummy another question about a vin.
ND - can you help with this one of a 59 F600 please? F6DC9E19168 Still researching - if I purchase I'll post some pics of this beauty. |
Originally Posted by Jack the Knife
(Post 16647473)
ND - can you help with this one of a 59 F600 please? F60C9E19168 C = 292 2V 9 = 1959. E = Mahwah NJ Assembly Plant. 19168 = 1959 Numerical Sequence of Assembly, the trucks specific serial number. |
