Not_His_F250's brake thread!!
Here are the symptoms
she still grabbs the Brakes while driving.... then after a while she releases them. Meaning she *hopps* rathen then drives, Brakes are hot after and smelly but so far no damage done. She also still has a jerky braking when your trying to stop. best I can explain it lol Here is what has been done Pads, Lines, Rotors, Calipers, all greased and looks good, bleed many Times & Changed Power stearing Fluid. 2 different Shops & 1 Hubby later she still does it so we going to replace Boost next. Then the Master ... and if she still does it after all that I sell her and buy a new Truck :) <!-- / message --><!-- sig -->__________________ |
Damn Pat, I don't know about the diesel system. Umm, abs system flaking out? Again, I don't know the diesel system but after all that there can't be much left is there? Main hubs ok? Just guessing.
But with the smell of brakes.. I dont know.
I would almost like to lift all four on jack stands and see what it does in the air.. |
Jasmin,
can you feel anything in the steering wheel when it happens? Do you feel anything in the pedal? is it in the back or the front that it gets hot? Or all 4? |
Originally Posted by just another truck
(Post 10432275)
she still grabbs the Brakes while driving.... then after a while she releases them. Meaning she *hopps* rathen then drives, Brakes are hot after and smelly but so far no damage done. She also still has a jerky braking when your trying to stop. best I can explain it lol Here is what has been done Pads, Lines, Rotors, Calipers, all greased and looks good, bleed many Times & Changed Power stearing Fluid. 2 different Shops & 1 Hubby later she still does it so we going to replace Boost next. Then the Master ... and if she still does it after all that I sell her and buy a new Truck :) <!-- / message --><!-- sig -->__________________ I'd check the ABS, can you hear the ABS motor doing anything when you hit the brakes and they pulse? You could try pulling the fuse for the ABS out too that should disable the system and see if it does it still. That's a cheaper test then replacing the booster or master. |
Originally Posted by 99F-350CrewCab
(Post 10432579)
Great suggestions, just sent her off a message to give it a try. |
Is brake pedal go down and will not go up easy or slow? Feel STIFF or spongy?
It use power steering pump to running brake system on diesel so is power steering fluid smell burnt or low on oil? iI wonder if AE scanner can find more info on abs system? I could give 1 try on mine f350 to see if it show info or not. Where city she live near so we can help her and inspect. |
trying to answer all Questions :)
I noticed before she does it the brake pedal is VERY stiff, no play. The pulsating can be fellt throughout the Whole truck, but yes also in the Steering Wheel. No noise when she does it ..... It smells from the Front and power steering Pump fluid has been replaced and is not low. feels like something is grabbing my tires,,,,,,,, I will have Mike check that Fuse when he gets home Saturday..... Thanks Guys... You cant amagine how frustrating this is !!!! |
how about the slide pins? are they sliding or stuck? my truck beat me to death when i hit the brakes.
hmmm No idea, will have Mike check it out thanks :)
Originally Posted by bcaughhorn
(Post 10433693)
We all thought slide pins in the begining, but Mike checked them, from there he went after the lines. |
Oh lol... Pat thank you for reminding me ..... hard to remember what all was done and checked anymore.
Goofy question, but what kind of pads?
No problem, just hoping we get something for you!!
Well I guess I should have found this thread before I posted in the other one. Sounds like everything I suggested has been done.:-huh
I would start looking for a bearing locking up, or the proportioning valve/ABS system. If you can smell brakes. The pulsation is the rotors. Take the stock ones off and throw them in the scrap pile. I have had the best luck with slotted and drilled rotors, never had any pulsation after. Make sure lugnuts are torques correctly and evenly. Rich |
