Ford Truck Enthusiasts Forums
-   1999 - 2003 7.3L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum31/)
-   -   How to test icp sensor to make sure they good or bad ? (https://www.ford-trucks.com/forums/1071174-how-to-test-icp-sensor-to-make-sure-they-good-or-bad.html)
Milwaukee1979F150 05-30-2011 09:29 PM
I can't afford buy parts and pray it work. That why I want test all sensors before buy new sensor.
I was wonder if you can test with ohm meter to see if they good or not?
What cause low voltage 0.02 and HIGHER rpm it 0.04
I keep get P1280
tdpower 05-30-2011 11:00 PM
I keep get P1280
What truck are you working on? I don't think your 5.4 would throw that code.....:-X04
Here is some more info: ECSD - Injection Control Pressure (ICP) Sensor - 1994-1997 Power Stroke FAQ
Milwaukee1979F150 05-30-2011 11:04 PM
it 2000 F350 7.3L powerstroke diesel
machmedic 05-31-2011 10:36 AM
Also check the inside of the sensor and the plug for oil. It's a sign its bad. Just changed mine, oil had gotten up into plug and the truck would die if you touched the plug.
