Reverse wire location
I'm getting ready to put in my new double din and it said to hook the wire for the camera up to the reverse light wire.
Anyone know which one this is on the harness coming out of the column? Thanks |
No help but the one that says ebrake just ground out
Looks to be a black wire with a pink tracer, but it's not on the column.
Here's a wiring diagram for the 2002: http://www.e-toolbox.com/ads/wiring/va153488.pdf Pop |
What Pop Says, Range selector is in Trans
Thanks guys!
I'm about to do the same thing. Can someone clarify for me where the wire is?
i want to clarify my earlier post
when you hook the wire specified as ebrake to a ground it will allow you to watch dvd's in motion |
Ya, I'm going to do the "Parking" wire to a positive so I can do stuff while in drive, but I'm going to have a back up camera. Where is the black/pink wire under the dash? If at all.
Trey,
Did you ever find the mysterious black/pink wire under the dash? I too am seeking the location of this wire inside the cab. Unfortunately, I don't believe I can defeat my reverse sensor as the radio I purchased shuts off the bluetooth phone feature when the backup camera is active. |
Originally Posted by djed
(Post 12244937)
Trey,
1 Attachment(s)
Yep there it is.. Goodness. Some of my early wiring was terrible. Maybe I will fix it.
2 Attachment(s)
Thanks for the pictures.
I spent a few minutes under the steering column and found a group of wires coming out of the wheel shroud that included a black wire with a pink stripe. The wires terminate into a brown plug. I've attached two pictures - one for perspective and one closer up. Assuming I found the correct wire, I hope this helps others. Attachment 201591 Attachment 201592 I'll confirm that I located the correct black/pink wire when the camera arrives and I start my install. |
So did djed ever confirm this wire worked for his reverse camera?
I'm installing one this weekend. |
Originally Posted by rocknrod
(Post 14294779)
(Post 14294779)
So did djed ever confirm this wire worked for his reverse camera? I'm installing one this weekend.
