Off Road Lights (Post Pics!)
I wanna add some off road lights to my truck. But I cant decide how to mount them. What are your opinions/ideas? Post pics of your off road lights.
I ran 4 KC 800 series lights (2 fog/2 beam) on a Randy Ellis bar on my 2000 F250. Loved the combo, lots of light. Didn't have much use for it once I moved to PA (from AZ), but they worked great out in the dunes in Cali...
https://www.ford-trucks.com/user_gal...oid=63058&.jpg https://www.ford-trucks.com/user_gal...oid=63060&.jpg https://www.ford-trucks.com/user_gal...oid=87418&.jpg |
Mine are probably smaller than what you are talking about, but I use them off-road. :D
http://i47.photobucket.com/albums/f1...D/IMG_0012.jpg |
I have 2 Hella 500 FFs mounted in my bumper they work great and are pretty cheap too
http://i899.photobucket.com/albums/a...Y/IMAG0117.jpg http://i899.photobucket.com/albums/a...Y/IMAG0118.jpg |
Originally Posted by 2011SD
(Post 10309517)
Originally Posted by 2000silverbullet
(Post 10309803)
Did you utilize an upfitter switch for those or are they relay'ed off the fogs? Looks good. I'd like to get something "stealth" in my '11 for the backroads of PA. :-X22
I only have 2, but they're PIAA Crystal Ion Fogs. I LOVE these things in the desert.
:-X22 http://i178.photobucket.com/albums/w...j/IMG_0567.jpg |
barthel did you mount the stud down thru the plastic valance or up thru the top then spin the guards around. Do they bounce around or did you reinforce the plastic with a brace? Just curious.
4 - 8" procomp lights on a custom made light bar.
http://i126.photobucket.com/albums/p...o/d8b51ca1.jpg |
Originally Posted by jlmotox
(Post 10311216)
Originally Posted by MisterCMK
(Post 10311227)
Originally Posted by wideglidewoody00
(Post 10310597)
Since they're essentially mounted upside down, you have to take the lenses off and turn them around, then put the guards on the right way. Only problem is, the vent/drain hole is at the top. |
Originally Posted by TreySpooner65
(Post 10311218)
What kind of winch setup you got there? is that the hide away kit?
(Post 10307724)
