1st Gen Lightning
I've been looking for hors and can't find anything on the differences between them and regular F150's. Aside from the engine and transmission, I mean. I also can't find anything aftermarket regarding the suspension for 80-96 trucks. Does the lighting have a different TTB than regular trucks? And how are all these people dropping these trucks, when I can't find anything online or in magazines for full size TTBs for lowering trucks. I've only seen some for Rangers/Explorers. I've barelly found anything for 2wd pre-runners.
The only difference is:
351w in the F-150 4.10/4.11 rear gears Sway bars front and back Bucket seats Other than that, they use the E4OD tranny, and everything else is basically the same.... You can get a lowering kit from Eibach, DJM, Belltech, etc.... Lowering shocks, tranny shift kit, and if you REALLY wanna drop $$$, www.Fastfordfiberglass.com sells fiberglass hoods, rollpans, front bumpers, fenders, cowls, and tailgates..... |
If you can't find anything listed , i would call DJM or belltech , theres a few guys in the 87-96 forum that have lowered them , they should be able to help you , the suspension and springs on the lightnings are not the same as the standard 150s , i think the frame is thicker to , motor wise its a 351w with gt 40 heads and intake , they have a flat tappet cam instead of a roller and are SD.....Lew
Originally Posted by SideWinder4.9l
(Post 10284290)
351w in the F-150 4.10/4.11 rear gears Sway bars front and back Bucket seats Other than that, they use the E4OD tranny, and everything else is basically the same.... http://img41.imageshack.us/img41/557...arisoncard.jpg OP: To lower a Lightning would be the same as an F150. Drop I beams in front and shackle and hanger in rear/flip kit. Just know that the Lightnings come from the factory lowered 1" in front(Springs) and 2.5" in back(leaf springs). |
LMC and BroncoGraveyard has everything you will ever need for your truck including drop shackles.
Thanks, I can't ever find anything on TTB trucks. I used to see ad's in magazines and online but mostly for prerunner/offroad i beams. I read somewhere thy also had increased steering ratios. Are they're sway's bigger than f250s?
I-Beams-$599 3"
Drop Shackles and Hangers-$259 4" Axle flip kit-4-5" Lowering coils-2" Lightning Coils-1" Those measurements are going from a factory truck, and adding them....The coils/beams will give you 5" of static drop...and the flip kit, and lowering shackle, etc will give you 7-9" of drop... With the flip kit, you'll need to do some C-Notch work... |
Every now & then you can find factory 93-95 Lightning springs for sale on the NLOC & Lightning Rodder.
Just have to keep your eyes open. ;) |
Copper head,
If you're still in the market for the Gen 1 springs, I have a rear pair and the factory rear sway bar. Scott |
95 f150 Dude-PM me about the sway bar....
(Post 10359419)
I-Beams-$599 3"
I did find the dream beams for a mere $345 per set...I'll have to find the link again...
Lightning ft springs
I have a pair of 94 Lightning front springs for sale. These will lower and stiffen a F150 a lot.
Do you still have the Lightning springs?
Yes, I still have them. $100 shipped. my Paypal is johnconnie75@hotmail.com
