MPG's on a 300 6?
Hi guys, some of you may recall me posting up about getting a 5.8 F250 buuut found out the other night that I will be on my own for gas and insurance next year (parents throwing me into the real world), soo I started looking into other options and I've come up with a few:
A. Keep my 96 5.0/M5 with about 12-13 mpg and just do some upgrades to help mileage out but its starting to lose oil psi and I can't afford to replace a motor.. B. Suck it up and get the F250 and work double time to pay for fuel, guessing it will be about the same as my 96. C. Get the 94 F150 4x4 with the 300, it should have the low end I need to pull with and now I need to know REAL world numbers for MPG on it. The truck is spot less.. It is the kind of nice that looks like its been kept factory and clean all its life 3000 is plenty fair if you ask me.. I really need some help and real info here, if I drive this truck like a grandpa and treat her right (the 94) what can I expect for fuel economy? And please don't throw any BS like 20+ MPG out there.. The most I expect to see out of it is like 17 MAYBE 18. I plan to run a simple, yet free flowing exhaust on it. Thanks for any help |
Oh yea, there is a 4th option.. But its my last resort as it puts me out of my job... Get a little ranger and hope for the best.. But I really need a full size.
i get about 12 w 33 in tires on mine... my brothers 300 gets 15 city and 17 highway..it is a 5 speed w 3.08 gears though
mine has a 2.73 rear end and gets around 12 in the city and like 15-20 on the highway, depending on how fast im going, how much weight im pulling, bla bla bla. your probably gonna average like 13-16 mpgs combined.
My truck is a 1992, F-150 Custom....300/I6, 5 speed, 2wd/longbed/standard cab......Has 3.08's, and a Cat back exhaust routed in front of the passenger side rear wheel....2-1/4" Pipe Btw....
Here is my numbers, by topping off the tank, not by the gas gauge... Driving HARD- City-9-11mpg Highway-13-17 Driving with eggshells under the pedal- City-14-16 Highway-17-20-ish Last TRUE highway trip I did, I drove 100.00 miles, and topped back off at 5.23 gallons....19.5-20mpg no matter how you count it.... I love my truck....Period...:-jammin |
Wow.. All those don't sound bad..
I may be able to afford to drive the 94 in that case.. Mine will see mostly country back roads, loads of about 5,000lbs for very short distances, and mixed city/hwy offten |
You should get between 9-15 mpg then.....Adding the weight.....
Also, a re-gear from 3.08 to a 3.55 will pull the rpm/powerband down a bit, to give a smidge better OOPH to get that load moving..... I have honestly contemplated a 351w swap....But decided against it, because of the mpg.... |
Well it being a 4x4 I would think it has 3.55's but who knows? I know both of my trucks had 3.55's.
The 87 and this 96. I need MPG more than oomph, I can always stick it in 4L to get her rolling.. |
I averaged 14 with my 300, 4x4 5spd. Not sure on the gears though.
Approx. 3-4 mpg is an automatic loss for the 4x4 drive train....;)
you will be happy with the 4.9l i also have been thinking about swapping in a 351 in my 93 f150 which is a 5spd(m5od) working on a converson to the ZF tranmission.
i did swap my 3.08s for 3.55ls and i also have 31s on their. when i did a 50mile trip up north with the bed loaded down with wood with the 3.08 gears i got 17mpg then when i swaped the 3.55 i get a bout 17 highway and 14 city empty. |
My 96 F250, 300, 5 speed with stock gearing got around 15-16 average.
My 95 4.9 with 3.55's gets around 12-15mpg city and 16-17 highway. I've had it since new and it has got 18 once, driving 55 mph. Good strong engine.
My 95 f150 with 4 inch lift and 33 inch tires is averaging right around 14 mpg. I have the 5-speed tranny, which helps. I also have 3.55 gears. It all depends on driving style, I can get near 16, or I can get 6. Depends on how hard I want to work my old motor. Mine also just turned 190k miles, and is in serious need of a tuneup. If you are constantly pulling that weight for short trips, don't expect to see mid teens.
Also, my driving conditions sound exactly the same as yours. |
Hm.. Well I could live with that.. Its a lot better than getting a ranger that isn't completely gay and getting the same mileage.
