Ford Truck Enthusiasts Forums
-   1987 - 1996 F150 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum28/)
-   -   What rear end (http://www.ford-trucks.com/forums/1059047-what-rear-end.html)
Farmboypowerstroke 04-15-2011 10:52 AM
What rear end
What rear end would be in a 1993 dually? I don't know if its f250 or 350 two or four wheel drive. They would all be the same right?
rla2005 04-15-2011 12:20 PM
It should be a Sterling 10.25". I am not sure if the dually versus SRW are the same?
nstueve 04-15-2011 01:48 PM
DRW's are Dana 80's I am pretty sure... Dana's have a 10 bolt rear diff cover and Sterlings have a 12 bolt.
Get the 2 digit numeric code off the door sticker under "Axle" and look it up on the chart. Then you'll know the maker and gear ratio.
http://www.ford-trucks.com/article/i...de_Chart_.html
Phy 04-18-2011 09:34 PM
Both my 93 F250 SRW and my 93 F350 Dually (cab & chassis) have Sterling 10.25s...
