1959 Ford delivery van value question?
I located a 59 delivery box van in fair shape, runs, drives-ok.. Trying to negotiate a price. Whats it worth these days? On the low side and on the high side? Any info or idea appreciated!
https://www.ford-trucks.com/forums/p...ictureid=67244 |
I wouldn't know what it's worth but isn't that a 55 grille?
Value on something like that is hard to really determine, but I'll give you my thoughts. Yes, it is a unique truck and you don't see many of them around. Of course there may be a reason you don't see many. Like my F5, the bigger trucks generally don't draw high dollars because you are so limited on model specific parts. With the trucks like mine, there are a lot of parts in common with the pick ups, in this case, that's pretty much not true. It looks like a P500, so the first problem is gonna be those widowmakers, unless it was an old UPS truck with the 22.5's. I'd like to get one like that, but only if I could buy it really cheap, like $500 or less.
It was newer rims on it, like white-spoke type truck wheels.. Not sure I can get it that cheap.. bummer..
(Post 10216245)
And, Ford did not supply this grille, only available from the body makers since all P Series were sold without a body. P Series: Ford sold them as a rolling chassis only with dash gauges and misc other bits and pieces. So many bakery's bought these things, they are referred to as bread trucks. Also used by UPS before they switched to the E350 rolling chassis first offered in 1975. The P Series (P400/500) rolling chassis was also used by various Class A motor home manufacturers, like Condor. When Frito-Lay disposed of 10's of 1000's of these trucks, many were re-painted white and converted to 'home made' campers, especially by hippies. It was larger than the VW micro busses also favored by hippies. If y'all buy one a these things, be aware that some parts are slim and none as they are P Series only and all are obsolete from FoMoCo. |
(Post 10216563)
No, because looks can be deceiving. This grille fits 1953/77 P Series Parcel Delivery only. Not the same as '55 F Series Trucks.
As I said before these grilles are identical to the '55 (or the '53 in the case of 53 and 54 trucks) EXCEPT they are shorter or more narrow or not as long. In other words the headlight buckets are closer together. |
Interesting info.. Pretty much talked me out of buying it! Thanks for the heads up about parts and value...
(Post 10216563)
(Post 10216563)
I found one of these in my favorite old yard once. The junk yard owner told me to look inside the van since sometimes they stick stuff inside. Well, there was the grille to this parcel delivery, in great shape because it was out of the PA Snows and rains. I thought wow! Awesome shape! even if I was looking for parts for my 54, I thought this could be sold to buy a good 54 grille, then I picked it up and carried it and something looked wrong. Took it to my truck and held it up and it was like 6-8 inches shorter, bummer! I guess they would be good to hang on your garage as truck art.... |
(Post 10221841)
Interesting info Bill. I realized the grilles were narrower for these trucks, I'm I understanding you correctly that the same grille was used from 53 to 77.
Old-timer quiz: do you remmber this guy on FTE? Purple53: The Art Home by Angel Hess
I remember the '53 broke down, it looks like he's got a new scam that keeps him from having to work for a living... "The themes for this project are based around the concepts of life, family life, peace, hospitality, and, naturally, art. I will be traveling around from place to place, spreading a peaceful word, staying in as many homes as possible for me, while doing portraits of people, their home, and their families. I will capture candid moments and audio of the household during the time I have with each host." |
Originally Posted by ALBUQ F-1
(Post 10222597)
I remember the '53 broke down, it looks like he's got a new scam that keeps him from having to work for a living... Abe, if yer patient with forming sheet metal, you could make a scaled down version of a '55 pickup, and put it on a lengthened early Bronco frame. :D |
Originally Posted by 52 Merc
(Post 10222063)
The 53 and 54 Bread vans used a grille resembling a 53 Effie, while the 55 and newer ones used that 55 looking grille for years and years afterward.
It's logical to believe that when the earlier part was obsoleted, the later unit was used as it's service replacement, which is what Bill's later catalog is representing as fitting 53-77. From my 1955 parts catalog, part numbers were BRAA 8200-A or B4J 8200-A for the 53-54 trucks, and B5J 8200-A for the 55 and later. It appears the grille and much of the front sheet metal was available from Ford through the service parts division. Service Part (replacements): Parts sold at the parts counter. The front end sheet metal parts for the P Series was not serviced after 1964. Parts catalogs sez: Contact body maker. If someone needs one a these 1955/77 P Series grilles (includes the headlamp assy's, lower valance), I know where a good user is. |
Originally Posted by havi
(Post 10222616)
Originally Posted by abe
(Post 10225172)
So you are saying get a good P-series grille and build a scaled down truck behind it! Brilliant!
