1977 f250 mud truck
77 f250 for sale. I rebuilt pretty much everything in it about 3 years ago. Has probably less than 10 hours on it since rebuild.
First off, it's an off-road truck, not a road truck or a show truck. Engine is ford 400, bored .030" over, comp cams rv cam double roller chain and lifters. High volume oil pump, roller rocker conversion, holley 4 barrel, 9.5:1 pistons, headers. Trans is a 4 speed manual, rebuilt everything in it, new seals and bearing. T-case is np205. Rear axle is a dana 60, full float, spindles are bored out with 35 spline shafts, new detroit locker, new bearings and seals. Rear driveshaft is custom made, uses 1410 u-joints. Has 5.38 gears. rear track bars. Front axle is a 78 ford high pinion dana 60. New spindles, bearings, seals, and rebuilt kingpins, Open diff with 5.38 gears, also has aftermarket outer axle tube seals. Body is in decent shape, definitely an off-roader though. Has 6" lift springs and i think a 4" body lift, trimmed fenders, and tube brushguard, rear rollbar, and hitch. Hood starting to rust. Tires are 44" monster mudders, about 50% tread left. New battery, is set up for dual batteries, i only use one though. Just changed voltage regulator. No title Have a spare t-case, spare trans case and assorted gears, lots of spare assorted parts, bearings, and gaskets and such. located in NE ohio. I'm selling it because i basically lost interest, barely use it anymore. I'd be interested in trading for a regular 3/4 ton or up road truck, not really interested in another off-roader, suvs, cars, or any project vehicles. Email me at RJR99SS2@yahoo.com if interested. http://img.photobucket.com/albums/v222/RJR99SS/Beef.jpg http://img.photobucket.com/albums/v222/RJR99SS/2wd.jpg http://img.photobucket.com/albums/v2...99SS/Poser.jpg |
i know you sed off roder but is it streat legol in iowa thers no em laws
doesnt have a title right? how do you get one? im in SE/ central ohio
I live right around the corner from you (seriously, about 3 miles), I noticed the truck was gone. did you sell it?
Wish you were closer
Originally Posted by caseihman94
(Post 10737064)
Yes, that would be why it's not there anymore. |
