what size engine do I have??????
ok so hope im in the right place. I have a 76 f-150. need to replace the engine, not sure how to tell what size it is, pretty sure its a 360, and possibly a 390. Anyone have any advice?
Welcome to FTE!!
Post your vin number and/or a picture of your motor. Also... Post a pic of your truck.. I like my truck porn |
Pull a spark plug and insert a dowel rod. Have a friend turn the engine over by hand. Make a mark at the lowest and highest point of the stroke. Measure the recorded stroke. A measurement of about 3 3/4" is a 390, a measurement of 3.5" is a 352/360. The 360 has a 4.05" bore where as the 352 has a 4" bore. No way to know bore for sure without removing the head. Unless you know the truck there is no guarantee what is in there is what it came with, so a vin is almost useless for IDing your motor. I'm guessing you've already easily seen that its an FE by the intake.
Oh and Welcome to FTE! |
Welcome to FTE
The engine code is the 4th digit of the VIN: 1975/76 F150 V8's: G = 302 2V (2WD only) / H = 390 2V (2WD only) / J = 460 4V (2WD only) / Y = 360 2V (2WD/4WD). 360/390''s share the same block. The bore is the same (4.05), the stroke is different. Stroke: 360 = 3.50" / 390 = 3.78" While it might have a 352, it's only possible if the engine's been swapped, cuz the 352 was cancelled after the 1967 model year run ended. 352/360/390 and etc FE engines have 5 valve cover bolt holes per side. The 302 has 6, the 460 has 7. |
If you are going to replace it with another FE, it doesnt matter if its a 360 or a 390 but I wouldnt consider replacing with a 360, go with the 390.
