How to tell which cylinder is misfiring without codes
I'm getting a solid miss, but it's throwing no code. Short of cracking the whole thing open and looking, can someone tell me if there's another way to see which cylinder is missing?
Start unplugging injectors, maybe Cheezit can give you a better idea.
Originally Posted by Maxium4x4
(Post 10160419)
Unplug... injectors... that are under the valve covers? Could you elaborate on how that is done?
naw there on top of the rocker box.
a quick search would have found..... https://www.ford-trucks.com/forums/9...connector.html |
Ooh, thanks much! I didn't find that when I was searching, but i couldn't seem to find anything when I was searching.
LMAO. I suck at the search function... I only knew about it because I started it. there was a lot of issue with people loosing the clips and I could figure out how they were doing it.
