Coolant Flush Question
Okay, I'm doing a coolant flush and coolant filter install today. I started to drain my coolant so I can begin the process and have a question...
I have only been able to get about 3.75 gallons of coolant from the drain on my radiator. Shouldn't I get a lot more (around 6-7 gallons) when it's drained? My degas bottle was at the "min" line so I wasn't low on coolant. Is there something I'm missing? This is my first time at this so I'm not sure what to expect. I did read the "Coolant Flush Procedure" in the Tech Folder but didn't really see any mention as to the amount of coolant that should drain and/or how to get it all out. Thanks for the help. :-X22 |
there will be a couple gallons stuck in the block/heads/heater core, ect. and it will simply need to be flushed out, thus the term "coolant flush".
I kinda figured, but wasn't sure. My truck has 120k and I bought it used so I have no idea if it's ever had a flush so I'm going to start with the Simple Green HD, rinse, then go to the VC-9 and then rinse until clear. Can't hurt to "over do it" I guess.
Thanks for the info. |
This has been beaten to death in the 6.0 forum. If you head down there and look around you should have all your questions answered.
But in short, you will need to add 3.5 gallons of concentrated coolant back in, and assuming you have pure distilled water in the block after all your flushing, that will give you a perfect 50% mix when complete. Pull the drivers side block plug if you have any question as to whether you got enough drained out. Also, be sure to pull the lower radiator hose to drain. That gets quite a bit more than the radiator cock will. |
Just got back from the 30 mile highway drive with the Simple Green HD. I'll flush one time and then add the VC-9. When done, I'll do the driver's side plug and radiator hose. Thanks for the tip. I guess I'll need to stop at the dealer while I'm out because they told me I only needed 3 gallons of coolant.
Good news was the original coolant kinda looked like apple juice so I don't believe there's any oil in there. I went ahead with the Simple Green HD to just make sure. Do it right the first time huh? Thanks :-X22 |
You should use large truck antifreeze when you fill it instead of regular automotive antifreeze. Something about the PH and cylinder pitting problem if you don't
Listen here boy:D (dont be sensitlve now) drain as much out the valve on bottom radiator and fill...call it a day,ya be just fine,do it again in 5 years:-X22
Well Rexhound, being sensitive is not one of my finer traits (so my wife says). :) So no offense taken.
I just finished about a 40 mile highway drive with the VC-9 and finished draining. I was real happy to see it wasn't bad at all. I was a little nervous after the Simple Green HD, it looked like coffee. I rinsed it once after that and it cleared up real nice. So as I type this my truck is running with the high idle mod on in my driveway with my first round of just water after draining the VC-9 batch. I figure a few more flushes and I'll be ready to install my coolant filter. If I wasn't running out of daylight I'd install my homemade CCV filter. I guess that's next weekend. :-X22 |
Good job:-X22, them there disel fuel burners sure do smell fine like peachs and wine.:-wink
Originally Posted by Dentom052
(Post 10138663)
Originally Posted by Javo
(Post 10138875)
I went with the Motorcraft Premium Gold. Bought it a few days ago at the dealership. Except they told me I needed 3 gallons instead of 4.
(Post 10138858)
I figure a few more flushes and I'll be reading to install my coolant filter.
Thanks bpounds for the vote of confidence. I did read the "Coolant Flush" in the Tech Folder so that was a HUGE help. I've gotten so many great ideas and fixes from you guys on FTE, I love it! :-X25 |
With 78 cents a gallon for distillate water at Walmart, I don't even play with engine plugs. Just buy enough water for 3 flushes or more if you desire.
I used FleetPride lifetime coolant. It is mixable with all other coolants, so I didn't worry about perfect flushing. Comes SCA balanced as well. |
Originally Posted by Kajtek1
(Post 10142914)
I am not sure about purified water. The reverse osmosis from what I learned gets pretty close to distillate water, but typical softeners get water softer by replacing calcium with sodium. That from what I have been told can be harmful to cooling system.
Than again, with 78 cents a gallon for real thing, I am not taking my chances. In the past I replaced several radiators because of internal build ups in them. Nothing sucks more than have coolant boiling while you are stuck in Las Vegas traffic at 115F. That was while using green stuff. |
